Question about Coffee Makers & Espresso Machines
My delonghi ECAM23.450 when turned on displays "heating up please wait" then nothing - sometimes it will show "general alarm" then nothing - the machine is clean and has not been used very often - any suggestions?
    Problem Solver:
  • 14 Answers
Check NTC sensor and heating element terminals. You should get resistance with multimeter or ohmmeter. NTC sensor should change resistance when you heat it up with lighter, finger or whatever heat source you have near by.
Posted on Jun 18, 2014
SOURCE: DeLonghi Rialto Expresso Machine EAM-4500
You need to reset it. Unplug machine, remove waste container and tray. Put the waste container back in without the tray and slide a knife under the waste container, close door. Plug in. It should reset. Turn off, replace tray and waste container and turn unit back on.
Easier, call their 800 number and they'll walk you thru it.
Posted on Mar 27, 2009
Dane1234
  • 25 Answers
SOURCE: eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
Posted on Jun 29, 2010
mnwarfield10
  • 452 Answers
SOURCE: My delonghi magnifica pronto cappucino
needs new motor and poss pcb assy ...needs testing.
Posted on Feb 28, 2011
SOURCE: My delonghi coffee machine says
have the same problem - is there anyone that resolve this ?
Posted on Aug 16, 2011
caroldon
  • 17130 Answers
SOURCE: My DeLonghi EAM3500 display "general alarm" and
It is best that you contact the customer care of DeLonghi and post your request. you can also register your product for support.
The power supply can be sourced after the price is confirmed as these are available only with their spares department.
click on;
http://delonghiusa.com/support/
Posted on Oct 19, 2011
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team De-Brewerz.com says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through De-Brewerz.com . If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
click on;
Oct 18, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
Aug 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Hi, I have a delonghi 3400 espresso machine. When I turn it on, it says "turn the steam knob". I turned the steam knob to "on" and nothing happens. I pushed all the buttons and...
you must purge the machine first, by waiting till the light turns on then slowly turn steam knob until a steady stream of water appears.Make sure unit is full of water.
Feb 17, 2011 | DeLonghi EAM3400 Espresso Machine
Eam3500 delonghi coffe machine
May 29, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Heating up please wait nothing happens then general warning comes on what can i do
Standard problem with some Delonghi coffe makers.
The problem is with heating device inside.
There is thermal fuse - that have production leak i think
Need to remove cover and repair this fuse
Apr 01, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
My Delinghi eam3500 has come up with general alarm, I have cleaned the unit like it says but it is still not working, when it turns on it says warming up, but it tries to warm up for ages but nothing...
The general alarm message after the machine taking too long to heat up -in deed shows a problem to reach the correct temperature.
So there are a number of possible causes:
the 2 heaters (water/steam) the NTCs(temperature control sensors)
the tempearature overheat-fuses. In my case it was the (water-)heater itself. Be sure to unplug the machine from power supply befor opening!!!
First test then-do the heaters warm up??.....carefull if they do-they are hot!!! If one of them doesn´t warm up- Unplug again!...and then measure the resistance of this heater-If the heater is ok,it should show around 50-58 ohms. If it shows indefinite resistance the heater is broken and you have to exchange it.
In case of both the heaters showing the~50ohms you will have to check the thermal resistors/fuse/NTC.
For me the two forums below wer of great help for me...of course they are in german...but didn´t you wish to learn a foreuage anyway???
Good luck and best regards
Wolfgang
Ref,:http://www.kaffeevollautomaten.org/forums
http://www.kaffee-welt.net
Dec 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
524 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
