A paperscasett is a tray or cassette that holds the paper in a printer or copier. If you are looking for a paperscasett for a Canon PC-D340 printer, you may be able to purchase one from Canon or from a third-party supplier. You can also try checking online retailers or office supply stores for compatible paperscasett.
To ensure that you are purchasing the correct paperscasett for your Canon PC-D340 printer, you will need to know the specific model and configuration of your printer. You may also need to consider the size and type of paper that you will be using with the paperscasett.
If you are having difficulty finding a paperscasett for your Canon PC-D340 printer, you may want to try contacting Canon directly for assistance. They may be able to provide you with more information about where to purchase a paperscasett or suggest a compatible alternative.
Because the paper size of your software like Word is "custom", and the paper size setting of the printer is "ltr", the printer won't print until you change the paper size to "freesize". Change it in "Additional Functions" menu on the printer (Canon D340). (Word will change the paper size setting automatically if you adjust the margins of your paper too far)
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Have you looked at the toner in it now for a model/part number? Have you checked the owner's manual in the list of consumables? That is where they will list it.
A simple Google search of PC-D340 toner brought up many results, showing S35 as the toner for it. Here's a listing on Amazon for around $30 for one
