Question about Garden
Dirt devil1600 pressure washer leaking where the 2 handle parts join together.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
If the handle parts are screwed together, get some plumbers tape. Wrap it with the tape at least 5 or 6 times. Screw together. If the 2 handles aren't well machined give it more wraps. You could also use silicon pipe sealer but it doubt the machine is that close of a tolerance.
Posted on May 10, 2014
4 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: pressure washer water leaking from gun
Depending on the manufacturer, you may purchase a rebuild kit for these very inexpensively. It's just a small pack of o-rings and maybe a spring or two. It would be a good weekend job, pretty simple to figure out, I've got faith in you. Thanks Dana
Posted on Aug 22, 2009
SOURCE: washer stops when handle released
unloader valve not functioning properly causes pressure overload and stalls engine
Posted on Sep 02, 2009
  • 615 Answers
SOURCE: excessive leaking on gun handle
The pressure comes from very sealed container and with the weather hot and cold usually the housing start to expand and let the pressure out…same with the hose. Fixing the unit may be more than the price for new one… If you like to try look at hardware stores, True Value, etc. for the parts…let me know
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Posted on Sep 17, 2009
My mcculloch fhh18a pressure washer is leaking at the handle ,I took it a part and replaced the seals on the hose know I don't remember how to put everything back together please help
I've had a look online and can't find any parts lists to give you a guide so my advice is get a neighbour with good DIY skills / local mechanic who can work out what goes where. Most bits will only fit one way. Its embarrassing I know, but look over their shoulder, then you will know next time and breeze through it with your new found knowledge.
Jul 02, 2015 | McCulloch Garden
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    How to fix 12POE-150 power washer leaking gun wand
    There are no parts available for the inside of the guns. All you can do is replace the gun.
    see parts in link.
    http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
    May 01, 2014 | FAIP 1500 PSI Electric Power Washer
    What are the components in the handle of a Ryobi RHP 410 pressure washer?
    Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou. ``
    Jan 28, 2012 | Ryobi Garden
    Water over flu
    This is usually caused by
    1. the dual pressure switch.... locateted in the top of the washer behind the control panel. It is a round switch about 60mm in diameter (usually green) with four to six wires connected to it. If you cant get a new one, try fiting a second hand one from a juncked one.
    2. there is a plastic pressure hose connected to the pressure switch that carries the pressure signal from the base of the washer bowl, if this line is leaking, it cannot supply the cut off pressure signal to the pressure switch and the washer will keep adding water. Try resealing the ends of the tube with silicon or gasket cement where it joins the washer bowl underneth and where it joins the pressure switch. Make sure you UNPLUG THE WASHING MACHINE AND RECONNECT ALL EARTH WIRES WHEN REPLACING PARTS.
    Oct 09, 2011 | Washing Machines
    My engine is working or seems to be working fine on my pressure washer but there is little pressure coming through the wand when I try to clean off my sun deck. Why is this? Thank you.
    There are a couple of reasons why you might get this fault. If the machine hasn't had loads of use I would suggest checking the wand for any dirt. You should be able to push and twist the lance from the handle, and then possibly the lance in half aswell. Once you have done this just firmly tap the tubes somewhere clean. If there was any dirt in the end it should dislodge and work fine again.
    While you have the lance off the handle, run the machine up and make sure you are getting plenty of flow through the handle. The other problem you could have would be worn pump parts. Servicing the pump can be tricky so if this is the case I would recomend taking it to your nearest dealer/service agent.
    Jun 13, 2010 | Karcher 2500 PSI Pressure Washer
    No pressure
    The handle needs replacing, usually these only last 1-2 years, rubber o-ring breaks down in the handle, it can be replaced but a good chance it will still leak. You won't have good pressure until the leak is fixed. I would say the pump is doing it's job. I just replaced a handle on my electric washer, which was doing the same thing yours is.
    May 01, 2010 | Karcher K 593 M Electric Pressure Washer
    1999 Sable Brake line fluid leak
    Cut that out. Replace it with a compression fitting. Bleed the system.
    Feb 27, 2009 | 1999 Mercury Sable
    The high pressure hose has been cut. is there anyway to safely join together. IT is a 2400 psi high press water hose
    There are hose kits to join the hose together. Do not try it with just a clamp as it might result in injurie. I am guessing you are not talking about a washing machine but pressure washer. A new pressure hose is not to expensive. You can get them for every brand
    Jun 19, 2008 | Washing Machines
    Dirt devil pressure washer
    Dirt Devil Pressure Washer ----- I have one.....gun broke, and I'm ready to just toss it in the trash! Other than the gun leaking (won't hold pressure) the rest is fine - you want it, send me an email william.watson@wlwatson.com.....wlw
    Mar 12, 2008 | Washing Machines
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
