Amilo 1450 display not working and in external diplay also not working
The Hard drive is running but the fan is not running.Any how there is no display.
  • 6 more comments
  • jean
    jean May 11, 2014
    The heat sink fan on cpu is not running.But there is no display.
  • jean
    jean May 11, 2014
    I tried external display but no display.
  • ranchhand May 14, 2014
    Hello Jean...sorry for the late reply, but your posts just today showed up, I don't know what happened. If the CPU fan doesn't work the unit will not boot up, that is to protect the CPU from burnout. Either the connector to the fan came loose or the fan itself failed. This is a hardware problem and you need a good service to dis-assemble the laptop and fix or replace the CPU fan. If you are into doing it yourself, Youtube may have tutorials you can search.
  • jean
    jean May 14, 2014
    Yes i check it with another cpu fan but it won't.But for me the main thing is no display.
    Just to clarify..... if the CPU fan is not working, you will not get any display on your monitor because the computer will not boot. There is no video because the computer is not powering the screen.
  • jean
    jean May 15, 2014
    Are you sure the display problem is because of CPU fan.Because i tried to enter BIOS with external moniter also.
  • ranchhand May 15, 2014
    I don't know if the CPU fan not working is the only reason, but it definitely will prevent the computer booting if it is not running. Unfortunately, this forum is not conducive to back & forth communication; I hang out at Suggets-A-Fix.com, a free computer help forum. I probably can help you more there. Log in and post in the hardware section if you are interested. Anyway, did you replace the heatsink fan with a new one or not?
    [additional]: entering the BIOS won't help if you can't see anything on the monitor. The hard drive powering up just means that it is getting power to the servo motor, but you can't see anything because there is no input from the CPU. The hard drive is a storage mechanism only, it doesn't make any calculations on its own.
    Sergeant:
  • 240 Answers
What fan is not running? The case cooling fan or the CPU cooling fan? Did you try to boot into Safe Mode, and did the computer/screen start working then?
Posted on May 10, 2014
Testimonial: "Its cpu heatsink fan.I tried another fan also but its not running.Then for display i tried external display also but no use.I hear the sound of HD running."
4 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Amilo Pro V2030 - Wont Boot
HI there
Have a look very close at the monitor for a very faint ghost image, if you see one then the inverter or inverter coil has gone.
Another way is to plug an external monitor to the laptop to rule out other problems.
Post back if you need to.
Good luck and thanks for using Fixya!!!
Posted on Feb 12, 2009
  • 508 Answers
SOURCE: Unit powers up can here Hard Drive and Fan Cd -
goto bios and see if you can switch to external
Posted on Jun 24, 2009
  • 928 Answers
SOURCE: laptop monitor problem
Try a system restore to a time that you it worked. Actually it sounds like a video card problem.
Posted on Sep 05, 2009
The display on my Amilo Pro V2030 is black after it fell on the floor. Does this necessarily mean that the display is dead and needs to be replaced or external monitor used? Could the problem be fixed in...
May be a loose connection, at best, at worst, HDD damaged, etc., etc., etc.. Does it boot? Fan spins? LED's Blink? Sound? Anything? If you connect a External Monitor does it work? There are cable at the bottom and rear of the monitor that can come loose.
May 04, 2013 | Fujitsu Siemens Amilo Pro V2030 Laptop...
Tip
Insight , the hard disk digital
Until recently the hard drive was considered strictly an internal computer(Dell Inspiron 1521 battery) , to handle only if another sosituzione hard drive or other emergencies . In recent years however the hard drive appears as a device more user friendly , comfortably installed outside the houses and , especially , can be transported anywhere without having to grip screwdriver and nails obviously this is called hard external drive , which is widespread on the market at great prices.
verbatiminsight-300-x-251.jpg Following this fashion comes from Verbatim a hard disk called very special Insight HDDThe first hard drives equipped with a diplay of Dell Latitude D800 Battery. On this screen, the resolution of 21 脳 128 pixels based cholesteric liquid crystals ( ChLCD ), you can display the capabilities of the device and the remaining space. Thanks to the diplay catareristiche then you can display this information even if disconnected from power , so a permettend minotoraggio full at any time.
This trinket is not only boasts an elegant and attractive , but capacity has not indifferent : the available memory is around 500GB with HP Pavilion DV2000 battery, and transfer data on travelers 408MBs through the interface USB 2 .0, from whom also receiving food. Within the software Black Backitup , which allows users to restore and backup files . Insight is already available in Italy at the price of 199 euros.
Related: PA3465U-1BRS battery Toshiba PA3451U-1BRS battery
HP 530 battery
on Aug 09, 2010 | Computers & Internet
Only ocationaly rebooting the system. most of the time it says operating system not found.what could be the reason.Please help.My system Fujitsu seimens amilo pro 2065
Hey, either a hard disk corruption or some missing/corrupt files - Solution: Format and reinstall your Operating system. If that doesnt work, maybe you need a hard disk replacement.
But before that, are you sure you haven't connected any USB drives or flash drives or an external hard drive when you computer boots up. That could be the reason. Solution: disconnect any such device before you start your computer.
May 21, 2011 | Fujitsu Siemens Amilo Pro V2065 Laptop...
My fujitsu seimens amilo pro 3515 wont boot. I turn it on and can hear it start to do something but then nothing on screen, only the sound of the fan running. Any idea what I can do?
check if battery is good or the adapter but if you sure the fan is rotating then problem maybe on hard drive or memory if you can do it, try to re-install it memory and hard drive and clean the memory or sata, ide slot. or check the operating system maybe it crash or file corrupt.
Feb 12, 2011 | Fujitsu Siemens Amilo Pro V3515 Laptop...
Hi when I turn on my fujitsu amilo pro v2055 it says operating software not found. Can anybody help
The operating system software is stored on the hard disk. The computer cannot detect the hard drive and therefore cannot load the operating system. It could be that it only needs reseating to get it operating again, if that does not work it could be a faulty disk drive or a faulty disk controller.
To test if the hard drive is OK, remove it and connect it to an USB hard drive adapter and plug this adapter and drive into a working computer's USB port. If this computer see this as an external hard drive and you can view the contents of this drive, then it is OK. If you cannot see this drive then it is faulty.
You need to replace the hard drive in your computer and install Windows again to get an operating computer again.
May 16, 2009 | Fujitsu AMILO PC Laptops
Try connecting it to an external monitor as the display may have gone out on you.
Feb 12, 2009 | Fujitsu Siemens Computers & Internet
Fujitsu siemens amilo laptop
Do you have any cd's in the cd drive or any floppys in? it could also be a usb flash drive or external hard drive. If its none of those check the bios settings and see if your hard drive is in the boot order. If its still doing it after that I would say it could be a corrupted hard drive or corrupted os on the hard drive. If all else fails try to do a system recover using the recovery cd's. if that fails its a bad hard drive.
Oct 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Motorazor V3 External Display not working
hi racie,
1st i want to tell u that there are 2 types of diplay in flip mobiles like urs. and there are 2 display LCD plates/chips inside it.
One of the LCD plate/chip of the external display is damaged. It is due to hard flipping of the mobiles.
I recommend u to go to mobile technician coz it is a physical problem.
Looking for ur kind feedback,
Sajan (sajwhat_2003@yahoo.com / sajwhat@hotmail.com)
May 05, 2008 | Motorola Mobility RAZR V3
Computers & Internet Logo
David Payne
David Payne
