Question about Refrigerators
Why is smell coming from behind neff fridge
There is a smell coming from back of Neff K4316X4GB refrigerator. Can you help please?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 51 Answers
The smell could come from many things. Food which fell behind the fridge, etc. A dead mouse, etc.
Move the fridge out - it has rollers. Clean the floor behind it, while at it, it become terrible unsanitary over years. Take a vacuum and suck up all the dirt around the compressor area. Your refrig will run better and become more efficient. Less cost of electricity. Pull out the pan under the fridge and empty the year long water it has collected. The pan must be pulled out from the front after removing the fake bottom panel connected either with clips or 2 screws in front bottom. The clips just unsnap when you pull the panel.
Posted on May 10, 2014
IFIXALL
  • 868 Answers
SOURCE: Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Posted on Jun 06, 2008
  • 1462 Answers
SOURCE: I have a Neff fridge
push something flexible down drain or put a small tube into drain hole and blow
Posted on Jul 02, 2008
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
SOURCE: neff fridge too cold
Neff have just said to me that the most probable reason is the seal not being tight enough
Posted on Nov 25, 2008
iwillfixforu
  • 619 Answers
SOURCE: Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
I have a Neff fridge and Freezer Model K4204x6GB03. The fridge is getting very cold and building ICe on the back wall of fridge and too much Ice on the bottom of the fridge under the vegetable tray
First, try turning down the temperature control on the fridge incrementally and see if that gradually over time helps. If not, you may need to unplug the fridge for 15 or so minutes, hope it will recycle and then plug it back up, setting the control to what would be normally considered to be a moderate setting. If that fails, call a fridge repairman who you trust, , ,
Jul 28, 2017 | Neff Refrigerators
Neff fridge door doesn't close all the way
Perhaps your refrigerator is not level.
Jul 14, 2017 | Neff Refrigerators
My Neff fridge freezer model K3965 is leaking - Puddles of water are appearing underneath and ice is accumilating at bottom off freezer. I have looked inside and can't see a leak but ocasionly can...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 08, 2011 | Neff K3965XO Side by Side Refrigerator
Feb 04, 2010 | Refrigerators
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
May 13, 2009 | Neff K4664 Top Freezer Refrigerator
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Neff fridge too cold
Feb 09, 2008 | Neff Refrigerators
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
