The error comes up and we are wanting to know how to fix it?
Communication error. indoor - remote controller.
Air Conditioning Fault Codes
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
SOURCE: air conditioner want come on
ceck the thrmo remove it and by pass the wires hold them together if the ac starts then replace thermosat
SOURCE: Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
SOURCE: Fujitsu Air CONDITIONER LEAKING AT FRONT INTO ROOM MODEL NO AST18
Ithought the service was free from the advertising..silly me...I use trades people who come and tell me what is wrong , that is a free quote, then I decide what I can afford.
Thank youfor your time.
