Question about Cameras
My Fujifilm Finespix S4200 won't turn on
Seems like the charger that charges the batteries has some problem too. Everything was perfect in the first place and now the camera won't turn on with these batteries nor with other. And the charger has to charge the batteries and then when they're charged, two green lights start blinking. But not the charger just shuts down after a while and I have to unplug it and plug it again to start charging. And the batteries seems never charged despite I'm "charging" them 3 days long by now.
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
If nothing helps, perhaps you should try a new set of batteries and or another charger.
To rule out the camera is defect, put in new alkaline batteries. If the camera starts up normal, you can remove them end concentrate on the batteries and charger.
Posted on May 10, 2014
  • 374 Answers
SOURCE: battery will not hold a charge.
Casio says:
Red blinking light = defective battery
No flashing light = possible defective charger.
What you can do is send all your stuff into casio and they will test everything for you and see what they could replace for you.
Posted on Nov 26, 2007
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
IrishDruid
  • 2712 Answers
SOURCE: I have a samsung L200
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
SOURCE: Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Posted on Aug 06, 2009
How do i fix my s4200 ,with shooting
read your manual , I would guess you have it in the wrong mode .
Apr 26, 2015 | Fujifilm Finepix S4200 Digital Camera
I don't know how to charge my fujifilm ax600 series
The AX600 is a camera, not a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you need to charge them outside the camera using a separate battery charger.
Oct 01, 2014 | FUJIFILM FinePix AX600 14 Megapixel...
I lost my fujifilm finepix jx 400 battary charger and i want to use my usb cable to charge it is it possible i plug it but it seems doesn't charge
The JX-400 is a camera, not a battery charger. Connecting it to a computer's USB port simply drains the battery faster since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say).
One source for a battery charger is http://www.overstock.com/Electronics/BasAcc-Battery-Charger-Set-for-NP-45-Fuji-FinePix-S610-J110-J150W/7124327/product.html?searchidx=3
Feb 15, 2014 | Cameras
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
How long do you charge fujifilm JV300 camera?
Remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power outlet. The charging is complete when the light on the charger turns from orange to green.
Jun 03, 2012 | Fujifilm FinePix JV300 Digital Camera -...
Gateway W350i won't charge new battery
1) the charger from power supply inside of the laptop is defective.some component is burn or open,or short.
2) Of course you must shure that the batteries new is o.k you must go where do you buy and test it in another computer for to see is charging.
God bless you
May 09, 2012 | Gateway Computers & Internet
Cant find a cradel for a205 fujifilm camera
The A205 uses two standard AA batteries. If you use rechargeable batteries then they must be charged outside the camera. Rechargeable AA batteries and chargers should be available at just about any department, electronics, and office-supply stores.
Apr 17, 2012 | Fujifilm Cradle Battery Charger for...
It is not charging,the charger is all right
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | FUJIFILM FinePix Z35 Digital Camera
I have a fujifilm digital camera its a finepixv10 i plugged the wrong charger into it now it will not turn on , can you help ?
As you have used wrong charger so you have to see if the problem is withe the camera or FUJIFILM FinePix V10 Zoom battery, Or if the battery haven't been charged by the charger, so the power is empty and you can't turn on camera, Then use a right FinePix V10 Zoom battery charger..
Apr 26, 2011 | Cameras
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
