Question about Air Vent INC. 54508 36" Whole House Fan
Why does my airvent whole house fan stop working intermittently?
The fan worked fine until it was about 3 years old, but now it works but stops working without warning; I turn it off, and it starts working again when I turn it on after some time has elapsed. What should I do?
  • Jane Chambers
    Jane Chambers May 13, 2014
    Thanks for the capacitor info. I called AirVent (the manufacturer) and they are sending me a new motor (They said the problem was probably worn bearings.). I assume the "capacitor" is in the motor assembly. Is it?ynot
  • Jhune Obias May 13, 2014
    good for them to replace the motor but the capacitor is a separate device from the motor, just observe after replacing the motor .
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
If fan was able to run normally after a while, you may have problem with the motor starting capacitor, this gives the fan the needed kick to spin , when your fan stops working this may mean that the capacitor have already over heated, turning it off for a while will give it chance to cool off then start up again, have the capacitor checked and replaced immediately.
Posted on May 13, 2014
HVAC Fan Blower Problem
sounds like the blower motor needs to be replaced.
Sep 05, 2012 | 2001 Lincoln Town Car
My whole house fan has been having problems. The motor gets very hot and turns off. After cooling, it can work again (though I am not keeping it on!) The whole house fan is a Sears fan. The original...
Ada, I think you have already diagnosed the problem. It's the Leviton timer. For whatever reason, it can not handle the fan motor without over heating. The best indicator, was the melted hot wire. Perhaps the switch was defective from the start. I suspect the timer was rated for a ceiling fan and not a whole house fan.
Hope this helps you and thanks for choosing FixYa.
Aug 25, 2011 | Heating & Cooling
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
Wipers work fine until it rains then intermitient setting stops
This appears to be wear and tear of the Interval Timer Relay, for the Intermittent wipe cycle.
Regards,DT
Aug 29, 2009 | 1998 Volkswagen Jetta
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Whole house Fan Stops running after 10 minutes
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Jun 20, 2009 | Ventamatic Direct Drive Whole House Fan...
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
Dryers Logo
114 people viewed this question
Top Air Vent Dryers Experts
Dan Webster
Dan Webster
Are you an Air Vent Dryer Expert? Answer questions, earn points and help others
