My split a.c bluestar showing f8 What is reason
    Novelist:
    Champion:
  • 373 Answers
There is a fault in the temp sensor on the indoor unit that is working with the cooling unit.There could be a Freon leak check the pressers with the unit running. If low on Freon then look for leeks and make repairs. If psi is good then check temp sensor and replace if needed.
Posted on Jul 02, 2014
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
E6 error in bluestar s split AC how to rectify
your ac is warranty status , please change
Feb 19, 2016 | Heating & Cooling
My bluestar split ac 3.ton showing on display light blinking..what is problem
could be a control board either in the inside unit or the outside unit
could be a simple start/run capacitor for the out side unit
best get a technician out to check it out so that you get the correct diagnosis and quote for repair.
Sep 16, 2015 | Heating & Cooling
Bluestar split ac indoor unit making abnormal noises. I have a 5 star 1 ton bluestar ac model 5HW12ZBI. It makes noise (kit -kit) when the ac trips off. The noise is minor during day time but it Ibecomes...
From your details i can observe the blower motor bearing worn out. or its side bushes in which there is small bearing that may be worn out. Replace it. Finally check for correct voltage too.
May 07, 2014 | Heating & Cooling
My split ac is showing f8 on digital screen
Need to add some details, what kind of system do you have? Suggest starting by reading the owners manual, either the paper one or one Google shows you on line.
Dec 28, 2013 | Heating & Cooling
F8 dispaly error in blue star split ac
hello,
i also find this problem in my bluestar ac then i callled authorized service man . then he did these steps :-
1> Replace the sensore ( you will find inside the ac wich will be red or brown in color)
2> then check wheather the wire is in good condition or not means
is it working or not.
3> then clean the outdoor unit filters and coils,
4> and check the proper supply of electricity..
Mar 15, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My videocon split ac is showing f8
my split ac is showing f8 on the digital screen
Aug 04, 2012 | Heating & Cooling
No spark and no power: Bluestar 36
Is there power at the outlet? I know that it is probably very hard to get to behind the heavy Bluestar, but it looks like you may have to pull the stove away from the wall and make sure it is still plugged into a working outlet. All of those stove functions are fairly separate, so to have all of them go out, you probably have a power supply problem. There may even be a break somewhere between the plug and where it splits off into the fan/light/ignitor parts.
Dec 08, 2009 | BlueStar RNB36 (Gas) Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
