Question about Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive
How to format the transcend 25m on mac - Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: i bought transcend 25m ts640gsj25m
Hi.
To start, please take in accunt that there is a good chance you won't be able get back your data.
If an USB drive is not recognized, then it is often faulty, and only in some case data recovery is possible.
If you clicked start and started formatting there are even less chances that the data can be recovered.
Fist thing that you should try is connecting the external disk to a different computer.
If the disk is still not detected, then the next step will be taking the hard disk apart and mounting the internal hard drive onto a different USB enclosure (eg.StarTech.com 2.5in)
If the hard disk drive is still not even recognized using different computers and enclosures, then the hard drive is physically faulty, and data will not be accessed if not paying an expensive service (cost over $800). You cannot use software recovery on a disk that does not get recognized by the operative system.
If the disk is seen by the system, but you cannot access the data you can attempt using a recovery software, but after starting a formatting, I doubt you will be able to recover anything.
Here recovery software:
Free file recovery software
Free Data Recovery,
USB Drive Data Recovery - Free software
Regards.
Ginko.
Posted on Nov 15, 2010
TimeDefensiv
  • 746 Answers
SOURCE: I bought a new Transcend
Use partition magic 7.0/ 8.0/ 8.2 or advance, make new partitions and then format it. Sure, your problem will resolve. Let me contact for further more information.
Best of Luck
Posted on Mar 13, 2011
bronk50
  • 27725 Answers
SOURCE: I formatted my Transcend Storejet 25M 500 on Bravia TV
Log on as administartor you see the computers administrator is the only person who can change the values of any hardware on a computer.
Posted on Nov 22, 2012
I have a Transcend StoreJet 25M 500G external, I have a problem because when I plug it to the computer it will just display a shortcut icon, I can't access anymore my folders saved. This happen wh
the attributes of your files and folders have changed, go to folder option, then click show hidden files, also uncheck show system protected files,..........download some attribute changes software for changing the attributes
Feb 04, 2013 | Computers & Internet
Nov 22, 2012 | Transcend Storejet 25m2 500 Gb External...
I want to format my transcend from mac how can i do it
Transcend produces different kinds of memory modules, including Random Access Memory, or RAM, chips for computer systems, USB flash drives and a variety of flash memory card formats, such as SD.
Transcend's flash memory devices are usually preformatted with either FAT32 or NTFS. Macintosh systems primarily use the HFS+ file system format.
You can format a Transcend flash memory card to the FAT format using the Disk Utility program on a Macintosh.
Insert the Transcend flash card into a card reader connected to the Mac.
Some Macintosh computers have SD card readers built in.
Open the Disk Utility program in the Utilities folder.
Click the flash card in the left column of the window.
Click the "Erase" tab.
Click "MS-DOS (FAT)" in the "Format" drop-down list.
Enter a name for the flash card in the "Name" box.
Click "Erase" to format the flash memory card to FAT.
Hope this helps
Oct 28, 2012 | Transcend ts250gsj25m storejet 25 mobile...
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I bought a new Transcend Storejet 25M 320 GB. When I connected it to my laptop, after the installation of the software by itsely, it said you need to format the drive. I pressed OK but the formatting...
Best of Luck
Mar 13, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I bought a StoreJet 25M 640 external hard drive. When i try to use it with my MacBook Pro I am told I have to reformat the HDD. Is this right? How do I do this?
It is dependent on whether you are solely going to use the Hard drive with your macbook or whether you may use it on a PC as well. If you are going to use it with just the mac format it in Mac format if with PC and Mac format it for a PC.
You format the drive using disk utility which can be found by opeing up the applications folder and then the utilities folder. Open up disk utility and then on the left hand side select your hard drive, then select erase from the right. For Mac formatting under Volume Format select "Mac OS Extended (Journaled)" then name the drive and then click "Erase..." For PC formatting under the Volume Format select "MS-DOS (Fat)" Remember reformatting will wipe any information from the drive.
Hope this helps.
Dec 15, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a 25M Storejet transcend hard disk 640GB. The transfer rate of the hard disk is very slow. Its about 700 KB/sec. What might be the problem?
The problem is that you have connected it to a "USB 1.1" port, which is much slower than connecting it to a "USB 2.0" port. If your desktop computer has a "USB 2.0" USB port, use it.
If not, buy an add-in PCI card to add "USB 2.0" ports to your computer.
Dec 13, 2010 | Transcend 640GB Transcend StoreJet 25D3...
After formatting my currupted external 640GB HDD (Transcend Storejet 25M),I can only save 10 or so GB of data/video before it gets unresponsive.At this stage,the computer itself (Vista) does not response....
The data on the external disk was corrupted because the hard disk from it was dying. Take it out of the case , put it directly in a desktop and test it with HDTune (the free version of course) -it will tell you the damage status and if it's recoverable.
If not then it's dead - junk it.
Aug 29, 2010 | Computers & Internet
Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive Logo
46 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
