VP322-HDTV10A POWER PROBLEM
Had VP322HDTV10A since jan. 09. When u turn on tv, vizio color goes from org. to blue and then turns off. After trying several times, we finally were able to get it turned on. we then just left it on all the time, then yesterday it went off totally and will not attempt to turn on at all. please help....
    President:
  • 1,077 Answers
Definitely a circuit board failure somewhere in the TV. Most likely a power supply related problem. Since you only had the TV for six months, it should be under warranty. Opening up the TV and playing around with it would void the warranty. And it may get expensive.
Here's contact info to get you started with the warranty:
Phone Numbers
Technical Support or To Place an Order
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 23, 2009
This tv is junk...
Posted on Mar 13, 2010
The sound on my vizio model no is vp322 hdtv10a comes on for a short time and then it goes off and the only time it will come back on is when I cut hte TV off and after a while and the cut it back on.
You may have a bad power supply, or the voltage regulators on the main board are flaky. It may be a bad capacitor, generally a visible difference from the other capacitors will indicate the candidate.
Vizio has a recurring problem with \'adjusable\' voltage regulators on their mainboards that produce the sub-5 volts components desire.
So, it is a component that is heat sensitive, has a bad / cold solder joint, or possibly the power supply capacitor that drives the sound ICs and amplifier.
Oct 27, 2014 | Vizio Vp322 Hdtv10a Crossover...
Vp322 hdtv10a have picture but no sound, what board is it?
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | Vizio VP322 32 in. Plasma TV
My vizio vp322 hdtv10a was on then just turned off all of a sudden. When i tryd to turn it on the vizio light comes on but the screen is still black.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise,
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to rectify the problem, and do take care in handling the TV, because it contains high voltages...
Jun 24, 2011 | Vizio VP322 32 in. Plasma TV
Hi my vizo 32 inch model vp322 hdtv10A has been flickering when it turns on and now their is no power and no lights and the tv wont turn on. what would be the cause of that?
Bad power supply, most likely. Take the back off and look around to see if any capacitors are bulged out. These need to be replaced with the same farad value, most likely 1000uF, but the voltage can be increased a little if need be.
http://www.youtube.com/watch?v=BNHHrgX_6cs
Video demonstration.
You can get these parts at Radio Shack, or on Ebay. Just see which ones are puffed and match the value.
http://cgi.ebay.com/Vizio-VP322HDTV10A-Power-Supply-REPAIR-SERVICE-/120683332030?pt=LH_DefaultDomain_0&hash=item1c194981be#ht_500wt_684
This is a powersupply. The capacitors are the ones with the + marks in the center of the circles.
Jun 24, 2011 | Vizio Televison & Video
When I go to turn on my Vizio 32' Model VP322 HDTV10A, it half turns on then back off, repeatedly for 3 minutes before turning on. How can I fix this problem?
If you are not able to hear sound during the this process, the power supply of the TV is likely failing.
If you are able to hear sound during the 3 minute ordeal, then likely the inverter for the backlight is failing, which can also be caused by a failing lamp as well.
Try this: turn the TV on, wait for it to do its thing. Goto the menus, picture settings, and turn the brightness *down* as far as it will go. Exit out of the menu (save if prompted). Turn the TV off, wait a bit, then back on. If still same issue, it could be the power supply or inverter / lamp assembly. But, if the cycle is shorter, or comes on right away, then it is likely the lamp / inverter.
Jun 23, 2010 | Vizio VP322 32 in. Plasma TV
Televison & Video Logo
477 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
