Hi there, try this. Press and hold th eend key on one of the handsets, while holding the end key, press and hold the # key. After 3 or 4 seconds tha thandset should beep and read deregister Handset and underneath that "Base Unavailible". Select base aunavailible and confirm. Then tha thandset should read "Handset not registered, place handset on base" Once you place the handset in the bace cralde it should register in 5 - 10 seconds or so. then you should be good to go.
I got the Uniden powermax phone from my sister but she didn't have the manual & I don'tttt...
(More)
I got the Uniden powermax phone from my sister but she didn't have the manual & I don'tttt know how to work everything. Is there any way I can get a manual?
We can't answer the phone from the handset unless the handset is close to the base. Do we need to...
(More)
We can't answer the phone from the handset unless the handset is close to the base. Do we need to run the battery down then charge it? How do we do that?
when i plug in the phone i have dial tone,when i place on the base i loose all phnes in the house....
(More)
when i plug in the phone i have dial tone,when i place on the base i loose all phnes in the house. it seem like it comes on.
I've lost my instruction book for my Uniden model #XCA650. How do I reset the number of rings before...
(More)
I've lost my instruction book for my Uniden model #XCA650. How do I reset the number of rings before machine is to pick up a message? Thank you. Patricia
