Question about Bakers Pride M1031X
Bakers pride xp series gas deep fryer pilot works but burners wont;
3 Suggested Answers
  • 125 Answers
SOURCE: WAISTING GAS BAKERS PRIDE GAS OVEN DOESNT SHUT OFF
Hi, don't know if you received an answer, however your gas valve sounds to be bad, when turned to pilot, it should only allow gas to the pilot assy. The problem is, it has already failed to shut fully, if it still does that with it in the off position, it would still be allowing gas through it, if the pilot goes out, there is now no protection to shut itself off, get it replaced ASAP. Hope that helps, and thank you.
Posted on Jan 06, 2009
Daniel S
  • 4323 Answers
SOURCE: i have a bakers pride
Hi
There are conversion kits available that you can use to convert your oven. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 10, 2011
Imperial gas fryer burner wont light
Check out the over heat is not shutting down to soon or thermostat is not opening ,
Sep 01, 2012 | Imperial IFS40 Deep Fryer
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Jun 15, 2011 | Pitco Frialator E24 Deep Fryer
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Nov 29, 2008 | Imperial IFS50 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Sep 28, 2008 | Bakers Pride C011-E2-C Gas Double Oven
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Bakers Pride M1031X Logo
55 people viewed this question
Top Bakers Pride Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bakers Pride Kitchen Appliances - Other Expert? Answer questions, earn points and help others
