Question about Air Tools & Compressors
Can't find repair parts for a central pneumatic air compressor.
I have a leaking gasket at the back of the motor, and can't find any place to purchase a new one to repair this. any idea were i can get one?
Eric,<br /> <br /> I just bought a Central Pneumatic air compressor from Harbor Freight and fortunately I have the manual and the contact number for you to call for parts 1-800-444-3353. This number and your model and serial number of your tools should get you what you need. Hope this helps<!-- from fixya rte -->
Posted on Aug 13, 2010
  • 2 more comments
  • marknphyl890 Jan 05, 2011
    Have you repaired your compressor?
  • Texan55 Feb 11, 2011
    I have a Central Pneumatic air compressor and loved it until the one-way valve quit working. Had the part no# and ordered a replacement. It was cheap and easy to order....but that was 6 months ago and I am still being told to be patient as it ..."will take a couple more weeks!" I will never buy any thing beyond a hand tool from Harbor Freight again.
  • docterry001 Feb 12, 2011
    yes I have repaired my compressor and it works great.
  • Jack Crow Mar 01, 2011
    where did u get the part to fix compressor?
  • 76 Answers
Make one all automotive part stores carry gasket material i would recomend napa and go to the counter and ask they should be able to help you out and answer any questions you have also
Posted on Jun 23, 2009
My centry motor 8-165730-20 burnt out and I need a replacement..what can I use as a replacement motor or where can I find the original part?
Posted on Sep 18, 2009
  • Dennis Kelly Oct 01, 2011
    Any good electric motor shop should be able to find a replacement motor, info that you need to get off the motor
    H.P.
    Volts
    Phase
    R.P.M
    Frame #
    Encl. " ODP of TEFC
Can I use another Central Pneumatic pump on my 61490 air compressor?
sure harbor freight tools sells new air compressor pumps, just be sure new one matches the R.P.M of the motor or I may damage it if it turns too fast of may not make enough air if it goes to slow , also be aware if belt pulley changes its diameter then pump speed will also change
Dec 05, 2015 | Air Tools & Compressors
Central pneumatic air comp model 9416797
Hi I have a central pneumatic 29gal 2hp comp when I turn it on it trips the breaker any answers
Sep 11, 2013 | Air Tools & Compressors
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
Head gasket leak but I found out that this part is no longer made due to non production its a centeral pneumatic oil less air compressor 99781,I was letting my air compressor build up air pressure when I...
If it is a head gasket leak and no gasket available. I would make one. You will need to buy a piece of high temp gasket material like garlock and it needs to be the correct thickness as the old material/gasket. Remove the old gasket and trace out a new one and cut it out. Or you can locate 2 bolt holes one on each side of the head put 2 holes in the material and use the bolts to hold it in place. Use a small hammer and tap around the edges. If done correctly while tapping it will cut the material. you can do bolt holes, the complete gasket like this.
Jul 17, 2011 | Air Tools & Compressors
I have a Central Pneumatic, 21 Gallon, 3HP air compressor. The compressor is exiting air through exthaust port.
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Sep 06, 2010 | Air Tools & Compressors
Need diaphram for regulator for central pneumatic 42321
I used a FORD master cylinder gasket number 42098. It is the right overall diameter and I used a hole punch, slightly oiled, in my drill press to put in the four screw holes. The hardest thing is getting the nuts back on the screws to hold the switch together. But it works for $5.
May 26, 2010 | Bel Aire Compressors Bel Aire 5 Hp Air...
Central pneumatic 2 hp 4 gal air compressor has too many air leaks how to fix
can you please tell me where are the leak found as there are different place with dif temp seal
Sep 23, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
10,706 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
