Question about Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model
Mower will start but blades will not enggggage
My Wheel Horse mower acted like low on gas so I filled it. Turned on the mower blades and off and on when moving and it seemed like a belt slipped. It ran unevenly, quit running and won't start.
Even if you have slipped or broken the blade belt, that would have nothing at all to do with keeping it from starting UNLESS you are trying to start it with the blades still engaged. Check that.
Jul 02, 2016 | Garden
Mower will start fine when I engage the blades it will mow for a short time then the mower wants to stall and will if I don't disengage the blades
Are the blades turning freely when disengaged. Is it possible something is interfering and binding them somewhat (for example, if the mower picked up some rope and it wrapped around the shaft to the blades)?
Apr 02, 2016 | Garden
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
Hit a rock and shut mower off now every time I engage the blades it shits the mower down
look for a fock stuck between the mover and blades under the mower. pull the plug off before trying this. turning the blade to release something can start the mower with your hands in there.
Apr 23, 2014 | Garden
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
19"electric mower
contact on switch are possible gone or worn.you can replace be yourself as long as yuo follow the old connection
Sep 01, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
