Question about Essentials CIFF7012 White 9 Cu Ft Fridge Freezer Bottom, A Rating
My fridge is leaking a lot of water onto the base o f the fridge where the salad compartments are. I'm constantly mopping it up and it's no more than 18 months old. Does anyone know what might be causing this?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 51 Answers
The warming and cooling cycle is off. Refrigerators cycle hot and cold, this allows the frig from not turning into ice. Remember the old days you had to leave the door open to defrost ?
There should be an adjustment at the bottom (in front) just below the front door side underneath the frig. Some have a knob, others have a screwdriver blade. Try that 1st, otherwise your compressor is going bad and not putting out the proper cooling. 18 months sounds awful short for a bad compressor. They can last a lifetime.
First I'd rush to find my warranty papers before time goes by, because no one will fix a compressor. Once a compressor goes bad it spells junk, buy a new fridge.
The other part that can go bad are the warming bulbs hidden in the walls, but usually the fridge stops cooling period when that happens because the electrical circuit is broken. One needs a closed circuit to make anything work. Also check if the compartment has a separate cooling adjustment, many have. The other thing to check is to look for
the cooling adjustment within the refrig itself, which controls the entire refrigerator. Turn it a notch at a time cooler. The main cooling adjustment is usually located on top in the upper portion within the fridge. Make a list of the items I mentioned, then check them off because I didn't give the causes in the exact order.
Posted on May 10, 2014
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also...
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
Oct 20, 2013 | Frigidaire Freezers
BEKO CG964 fridge/freezer - base of fridge flooding with water underneath salad drawers
I had the EXACT same problem. I've just used a wire coat hanger and pushed it through the hole that the plunger couldn't impact and all the water drained out perfectly! Problem solved!
Jul 02, 2012 | Refrigerators
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
Essentials CIFF7012 White 9 Cu Ft Fridge Freezer Bottom, A Rating Logo
55 people viewed this question
Top Essentials Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Essentials Refrigerator Expert? Answer questions, earn points and help others
