Question about Select Brands BB-10
How do i fix error on my blackberry q10 - Select Brands BB-10
I have an E01 error code on my West Bend slow cooker, how do I fix it?
Find out what the error code alludes to and rollup sleeves and .....................Could be something as simple as an open heating coil.
Feb 05, 2017 | West Bend Crock Pots & Slow Cookers
Tip
West Bend Crockpot EO1 Error Code
<p>Your crockpot is giving you an <b>error code EO1</b>. Now you need to know how to get the code off of your crockpot so that you can use it. <br /> <p><br /> <br /> <p>First, let me explain what the code means. That code tells you that your <b>temperature sensor</b> did not calibrate correctly. Do not worry, this is usually just a temporary situation and the sensor can be reset through a few very simple steps.<br /> <p><br /> <br /> <p>The first thing to do is to unplug your unit from the electric socket. Leave it unplugged for at least ten seconds.<br /> <p><br /> <br /> <p>Then plug it back into the electrical outlet.<br /> <p><br /> <br /> <p>When you have it plugged back in, hit the <b>POWER</b> button once and then within one second hit the <b>COOK</b> button once.<br /> <p><br /> <br /> <p>Now the appliance should be ready to use.<br /> <p><br /> <br /> <p>If you have the problem again just repeat these steps to clear the error code.<br /> <p><br /> <br /> <p>This is how you can easily <b>fix the EO1 error code.</b><br /> <p><br /> <br />
on Feb 08, 2011 | Crock Pots & Slow Cookers
I have p9982 blackberry my problem is that it doesnt get started.it shows bb 10 0015 error
Try this:
http://uk.blackberry.com/support/error-codes/os10/error-bb10-0015.html
May 01, 2014 | Select Brands BB-10
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
Jan 14, 2011 | West Bend 84496 6-Quart Slow Cooker
West Bend Slow Cooker error code: "E01". - holding "cook" button while plugging/unplugging did not fix the problem.
if you put something frozen or cold in it and let set for awhile without turning on then you must take it out let unit get room temp. then start it . E01 error means the unit is too cold to start.
Dec 22, 2010 | West Bend 84496 6-Quart Slow Cooker
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Crock Pots & Slow Cookers Logo
66 people viewed this question
Top Select Brands Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Select Brands Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
