Cell Phones Logo
Mary Johnson Posted on May 10, 2014
How do I connect my Nokia 113 to my laptop or iPad using bluetooth
I can't connect
3 Related Answers
Anonymous
  • 161 Answers
  • Posted on Jun 25, 2008
SOURCE: Connecting my PC to Internet through Bluetooth, using Nokia N73
Try opening Nokia PC Suite, click settings, then Manage Connects. Check the "blutooth" check box as well.
Anonymous
  • 52 Answers
  • Posted on May 13, 2009
SOURCE: unable to pair with PC via Bluetooth
beter to uninstall the pc suite and reinstall it.
atk_saravan
saravanan
  • Posted on Apr 01, 2014
SOURCE: can I connect nokia E5 through bluetooth to access internet on my Laptop
I am not able to cancel the download images. It is showing system error. How can I cancel the same?
1helpful
How to pair bluetooth keyboard with ipad mini?
Hi Douglas.
1. Switch on BlueTooth on your keyboard.
2. Enable BlueTooth on your iPad.
3. Search for devices on your iPad.
4. Press button if available on keyboard to get discovered.
5. Select keyboard when shown in devices list.
6. Enter pairing code sometimes 0000 or 1234.
7. Use and enjoy.
Hope this helps!
Here is the Apple site instructions:
Using Bluetooth headsets and keyboards with iPad
Here is another that explains how to do it on a MAC, might give you some clues as well:
Bluetooth How to set up your Apple Wireless Keyboard
Here is a good independent site, maybe start here:
iPad How to pair connect any bluetooth keyboard
If you prefer to watch how to do it on YouTube:
How to Connect Pair Bluetooth Wireless Keyboard to your iPad
1helpful
2answers
My speaker does not connect to my ipad
The speaker has to be paired with your iPad before it will work. Check your documentation on how to put your speaker in "discoverable" mode long enough for the iPad to find it. If you have previously paired your speaker and it at one time did function is your iPad, make sure that Bluetooth is turned on on the iPad. Also, check the batteries on the speaker if it has previously functioned with your iPad...
How do I connect my Nokia 113 to my laptop and iPad
The question is what exactly are you trying to connect to your phone to do?
Although the answer to that question is not that important, because everything you need to do between your phone and your PC you can do with Nokia PC Suite.
As for connecting your Nokia to your iPad, it's not going to work. You will need a phone that can produce a Wi-Fi hotspot, and this phone cannot do it.
1helpful
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_60e0f57ba319f3f6
How do I connect the key board to my iPad?
read the manuel. should do the trick.
make sure bluetooth is "ON" on the iPad.
6helpful
3answers
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
3helpful
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Can my motorola hH695 be paired to my iPad?
Hi, this instructions works on some iPads, you can try it on yours.
How to Pair A Bluetooth Device With The iPad
Among the many convenient features of the Apple iPad, the ability to pair the iPad to any Bluetooth device is very convenient.
Bluetooth devices allow your iPad to interact with devices ranging from headsets to computers without the use of wires.
Like most things related to the iPad, connecting an iPad to a Bluetooth device is easy. Follow these simple steps to do so.
Instructions
Things You'll Need:
* iPad
* Bluetooth Device (headset or other)
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this.
Typically, it just involves holding down a button for a few seconds.
Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears.
Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on".
Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad.
Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password.
Tips & Warnings
A white Bluetooth icon on the top of the screen indicates a device is connected to the iPad
A gray Bluetooth icon on the top of the screen indicates Bluetooth is on but no device is connected.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
