Question about Vacuums
Hoover jet n wash 1400
Ive followed the instructions to use the cleaner but when turned on it wont spray any water out of the tube. Cant find a blockage or anything what do i do
SOURCE: Hoover Steamvac hose won't spray water
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Posted on Jun 21, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 4 Answers
SOURCE: hoover steam cleaner spin scrub brushes wont turn
I just brought mine home...assembled per instructions and tried all the troubleshooting thus far to no avail. So I popped off the brushes per instructions and took a screwdriver to the hole where the brushes axle inserts underneath the vacuum and turned the whole manually. This either a) loosened it a little from the factory or b) moved the blades that the centrifuge was forcing to more optimum positions. In either case, the blades started working. note: when you turn, you should feel some resistance. As others noted, if it doesn't turn at all, turns way to freely or doesn't turn smoothly, then it's a bearing issue.
Posted on Apr 21, 2010
  • 4 Answers
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
Posted on Aug 31, 2010
heatman101
  • 43501 Answers
SOURCE: My Bex Bissell Proheat carpet cleaner refuses to
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rjm
Posted on Sep 30, 2010
Testimonial: "Many thanks for the link - I'll give their suggestions a go"
I stored my FH50220 in my storage unit over the winter and now it will not spray water
If your storage unit got below freezing it may have frozen and damaged something. It's hard to drain all of the water from pumps, tubes, valves, heaters etc. inside a carpet cleaning machine. If a machine must be stored where it may freeze one way to keep it from freezing up is to pour automobile windshield washing solution into the fresh water tank and run it through the machine until it comes out all of the Jets and cleaning attachments. Remove the fresh water tank and continue to run the solution through the machine to flush the windshield cleaner out of the machine. Be sure to use a cleaner with the proper anti-freeze rating and run fresh water through the machine before using it to clean carpets.
Apr 01, 2016 | Hoover FH50220 Vacuum
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Our Bissell 9200 carpet cleaner will not spray cleaning fluid through the tools nozzle. With the tool dial set to "floor" fluid comes out of the front nozzle. With the tool dial set to...
Assuming this is the pro heat version
Most likely you have some debris blocking the system. You need to follow the hand tool cleaning instructions.
remove the hand tool and manually wash it
select the tools cleaning option
place the tube in a bowl of clean water and allow it to **** the water up - this should clean out any blockages in the pipe.
Dec 14, 2010 | Bissell 9200 Upright Vacuum
Hoover Steam Vac ; The vac is not dispensing cleaner/water. I suspect the tubing/path from tank holding the cleaner/water mixture is clogged. Is there an easy way to unclogg it. Are there are...
Just a quick clarification please. Will the water not spray in both the attachment hose as well as the floor part? Or does it spray in one or the other. You suspect that it may have a clogged line, is the machine doing anything in particular that makes you think a clog?
Thanks,
CJ
Apr 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need instruction manual for goblin 1400 2in1
I have a hoover steam cleaner (f5835)didnt get instruction-I tried to use it with water(hot) and cleaner- >>when I finished nothing in the bottom- I did use water and cleaner??what I did do wrong? Could I get manual- I thought I had it in the box- but it instruction how to put it together Betty Smith- BJ_SMITH@ATT.Net
Dec 02, 2008 | Vacuums
Hoover Jet and Wash 1500w S6254 001. Used once with great difficulty as assembly and use instructions are hard to follow.Now will not work as carpet shampooer at all, although assembly is correct as far as...
i am having the same prob my uncle got me one i cant find the manual anywhere to set it up the prob i have is where does the handle to make the water go out connect tooo ??? on the main pipe that sucks it back up i have tried every which way but not the right way obviously lol as for it not spraying mine did for all of 2 secs but think it was because i got a bit happy with the solution so gunna just try water and if its too hot it stops it spraying properly too !!
Mar 30, 2008 | Vacuums
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
