How to apply function to a polynom
I have a fx-9750g2 model calculator. I want to apply function ,forexample newton function, on any polynom. I need answers urgently...
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
You can download the calculator manual here:
http://support.casio.com/pdf/004/fx-9750GII_Soft_E.pdf
It has over 400 pages and includes detailed help on functions.
I hope this helps.
Posted on May 10, 2014
How can I put fractions in the Casio fx-9750G2( Roman numeral 2) ?
The key to use to enter fractions is the one marked a b/c, just below the x, Theta, T key.
Jun 01, 2015 | Casio Office Equipment & Supplies
How do I factor polynomicals by grouping with fx-115es plus
You do that by hand. The calculator does not do algebra.
Jun 22, 2014 | Casio FX-115ES Scientific Calculator
A stress computation is 23.7389 N/mm^2 Express the result in preferred SI notation to three significant number
The SI unit for stress is N/m^2 (Newtons per square metre not Newtons per square millimetre) The figure above should be 23 .7389 * 10^ -9 or 0.0000000237389 N/m^2
Feb 16, 2014 | Casio FX-115ES Scientific Calculator
How do i calculate the normal probability value, give z-value, on casio fx-82ms
The fx-82MS does not have any built-in functions for calculating the normal probability distribution or its related values. You can calculate it using the defining function or any of a large number of approximations. Alternatively you can look up the values in a table.
Some advanced calculators have the functions built in, and programmable calculators can be programmed to give them. Sadly the fx-82MS is neither.
For more about the normal distribution, see http://en.wikipedia.org/wiki/Normal_distribution
Jan 21, 2014 | Casio FX-82MS Scientific Calculator
How do I enter a polynomal into the calculator. I need to be able to do factors with letters in it
Well, the short story is that this calculator cannot do symbolic algebra: it does not have a CAS (Computer Algebra System). However you can enter symbolic expressions using the variables A,B,C,E, X and Y. Use the sequence [ALPHA] [A] to enter the letter A, etc. To type in the symbolic = sign, use the [ALPHA] followed by the key at the top left corner of the keypad that has an = next to it.
When you enter an equation (two expressions linked by an =), press [ALPHA][SOLVE] to solve the equation for tha unknown X. You will be prompted to enter the values of all other letter symbols : A,B,C, D, Y, etc. When all symbols (except X) have been given a value the calculator will find the value of X that satifsfies the equation.
Jul 12, 2011 | Casio fx-300ES Calculator
Is there a way to convert newtons to lb or any operation which involve newtons?using fx-115ES?
There is a sloppy shortcut that people make in converting a unit of force (the newton) to a unit of mass, which they call kilogram force.To convert from newtons to kgf multiply by 0.1020. All you have to do after that is to convert the kgs into pounds using the equality 1kg = 2.2 04622476 lb.
See the screen capture (from page 48 of the appendix to the manual.
Jun 07, 2011 | Casio FX-115ES Scientific Calculator
How do you find sine cosine and tangent on a fx-9750g2 calculator?
First you must setup the correct angle unit (as required by the problem you are solving).
  1. Open the [Run] application screen.
  2. Press [SHIFT][MODE] to enter (SetUp)
  3. Use down arrow key repeatedly until you see the line Angle:
  4. Press the F1 key to select Degree as angle unit. or F2 for Radian.
  5. Quit the setup configuration screen to return to the main Calculator screen (RUN/MAT).
Once the angle unit is correctly set,
  1. Press the function keys [SIN], [COS], [TAN]
  2. Depending on what function you pressed, the command sin( or cos( or tan( is displayed.
  3. Type in the angle value,
  4. close the right parenthesis and
  5. press [EXE]
A result should be displayed.
Feb 13, 2011 | Casio FX9750GII Graphic Calculator
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
