Question about LG NB3530A
Lg how to connect - LG NB3530A
Hi I have LG KP175 mobile, I am trying to
try to go in control panel of ur pc then modify/repair the lg sync if it works then good otherwise try to update the version...
Sep 02, 2009 | LG KU990 Viewty
LG PC Suite does not detect the LG KS360 phone!
You need to change the usb connection type on the LG. By default it is set to "mass storage", if you change it in your "connection" setting to "data storage" when you next plug in your phone, it will have all of the PC Suite settings available without any grayed out non-functionality.
Jul 22, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
No Phone Connected
you need to switch to the correct mode on the fone first (menu connectivity - usb connection)
Feb 03, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Connect the lg mobile to pc
HAI,TO CONNECT INTERNET THROUGH CABLE OR BLUTOOTH.
(i) 1.CABLE : INSTAL DRIVERS FOR THE CABLE AND LG PC SUITE,RESTART PC THEN CONNECT DATA CABLE BEDWEEN PC AND MOBILE.IT,S ORIGINAL CABLE DRIVERS ARE AUTOMATICALY INSTALED,ORDINARY CABLE MANUALLY INSTAL DRIVERS.
2.THEN FOLLOW TO CONNECT INTERNET:
   START>CONTROL PANNEL>SELECT NETWORK     CONNECTIONS>SELECT CREATE NEW CONNECTION>FINISH.RESTART PC AND THEN CONNECT INTERNET THROUGH NEW CREATED IN NETWORK CONNECTIONS.
(ii)VIA 1.BLUTOOTH:INSTAL BLUTOOTH SOAFTWARE(BLUE SOLI) AND RESTART PC.
2.ON BLUTOOTH ON MOBILE AND CONNECT MOBILE TO PC (BLUESOLI).SELECT DUN INTERNET CONNECTION TO INTERNET.
Jun 30, 2008 | Computers & Internet
Cannot connect using LG internet cube software
You need to take the phone into your mobile center and have them manually assist you with this setup.
May 24, 2008 | LG Shine KE970 Cellular Phone
The_Wise23 - delete and try reinstalling your lg usb modem if that does not work call your provider and see if they can assist you more.
chinesebox - the best thing to do is uninstall all lg software and then reinstall it.
for all other users un-install then reinstall
Feb 17, 2008 | LG Shine KE970 Cellular Phone
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
Dec 17, 2007 | Computers & Internet
LG NB3530A Logo
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
