Question about Kitchen Appliances - Others
Empress bread machine
Only one kneading paddle is spinning.
jyackle5
  • 8197 Answers
SOURCE: Need part
This is the only one I can find.
http://www.ioffer.com/i/81565036
Good Luck
Posted on Jan 14, 2009
KMusselmann
  • 247 Answers
SOURCE: Want to buy a kneading blade. Toastmaster bread maker 1171
Hi. You can get it here. Pls rate the answer
Kurt
http://breadmakerguru.com
Posted on Apr 22, 2009
SOURCE: Bread Machine not kneading
http://www.breadmakerguru.com/search.aspx?s=tr900
This site has bands/belts for breadmakers. I am buying my new paddle for the tr900s breadman pro from there. Perhaps your belt is broken? I personally have never replaced one, but it should not be too hard. Make sure you unplug the breadmaker before opening it up at all.
Try running the breadmaker with no pan in it and see if the paddle shaft turns at all during the cycle. Also, the paddle will not turn at all in the first 30 minutes of certain cycles, like the whole wheat. This is stated on the time chart of the instruction manual for this model.
Hope this helps!
WestHof
Posted on Aug 19, 2009
  • 433 Answers
SOURCE: sqeaking when kneading oster 2 loaf bread machine - how to oil?
Take out the bread pan and go to a kneading cycle. See if it is squeaking. If yes, then it could be the belt squeaking on the pulley or the motor itself. If it does not squeak when the pan is out, then it's the bread pan paddle and sealed bearing. That sealed bearing is lubed and sealed. It can't be oiled. Hank
Posted on Jan 18, 2010
Testimonial: "Thanks, Hank - we will just live with the noise until it dies, then buy a new one."
  • 3 Answers
SOURCE: My bread maker doesn't knead correctly.
I had the same problem with my Breadman TR845. I made the first loaf O.K. but the knead paddle would not turn much when it had flour in the bread pan. I took it apart and discovered that the timing belt had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle a little. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the toothpaste cap in half and had to use a metal file to get it the right size. It needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the space so that it could slip over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are lots of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Posted on Nov 19, 2010
Can't get knead bar on West Bend automatic bread maker
Was the bar ever installed on your bread maker? Is this a replacement knead bar (paddle)?
Jan 01, 2013 | West Bend Bread Maker Machine Knead Bar...
The motor will turn on it's own but will not turn the kneading blade in the pan when that is put into the breadmaker. makes a soft "thunk" as it tries to turn it. It's like the gizmo at the...
Hi, First, the take empty pan and paddle out of the machine. Try to spin the paddle by hand. If it spins freely that's great. If it does not spin freely the sealed bearing that allows the paddle to spin has failed and you will need a new bread pan. If everything is okay, keep the pan out of the machine and go to a kneading cycle. Look through the window to see if the motor shaft is turning. If not then the belt is loose or fell off. Hank
Nov 02, 2010 | Sunbeam 5891 Bread Maker
The bread machine will not knead m I have made sure it is connected right and even started over with a new batch, it makes the nosie like it is trying to work but will not knead.
Hi, A few things may cause this problem. Make sure the bread pan is inserted correctly in the machine. If ok, then take the bread pan out of the machine and see if you can turn the paddle by hand. It should turn nice and smooth, If it sticks or does not move then the sealed bearing that the paddle spins on has failed. If that's okay then keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning smoothly. If no then the belt is loose, broken, or has fallen off the pulley.. Good luck Hank
Jun 04, 2010 | West Bend 41077 Just For Dinner¿...
Loaf of bread...clumpy mess
Hi...
Yup check those belts. Also make sure the paddle spins freely when you spin it by hand. If the paddle does not spin freely, then the sealed bearing may be going bad. Hank
Apr 11, 2010 | Black & Decker B2300 Bread Machine
Drive shaft no longer turns kneading blade on model k6725
Either the paddle is frozen in the bread pan ( take pan & paddle out of machine and see if you can turn it by hand), or the belt has fallen off or has snapped. (Keep the bread pan out of the machine & run a knead cycle, look through the lid window and see if the motor shaft spins. Hank
Mar 05, 2010 | Regal Ware Kitchen Appliances - Others
I have a brand new West Bend "just for dinner" bread maker. In the bottom, the two-pronged part which the motor is supposed to turn, doesn't turn. Thus, the kneading spatula doesn't turn. The heating unit...
If the machine is brand new, then take it back for an exchange. If that's not possible, then call West Bend for a replacement. If that's not possible then let's try to solve this problem in a few steps. 1) Take pan out of machine and see if you can spin the paddle on the shaft. If yes...next step..if no then bearing in bread pan is stuck. 2) Put bread pan in machine and lock in place. Start a kneading cycle. Look through plastic lid to see if paddle turns. If no step 3. 3) Take pan out of machine and start kneading cycle. If motor shaft does not turn, then the belt fell off the pulley in the machine or belt is broken, or the motor is bad
Hank
Nov 15, 2009 | West Bend 41077 Just For Dinner¿...
The knead paddle on my bread machine is stuck, what can I do to remove it. I have tried putting soapy warm water in the bread pan and leaving it sit for 30 minutes, but it did not work. I recieved this...
just go to youtube and type in "how to remove a stuck bread machine paddle or kneading blade" you will see my video of how to remove a severely stuck bread machine paddle.
Apr 20, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
23 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
