Question about Dishwashers
I just moved into a house that has a Maytag Quiet 300 dishwasher. After about 2 weeks, I'm hearing a VERY loud, almost grinding noise about 6-7 minutes into the wash cycle, then again near the end of the wash cycle. It sounds like a motor thing and I'm hoping to avoid a repair bill right now, the cost of the move wiped us out. Is this something that I can fix, and if not, will continuing to run the dishwasher with the noise kill it?
  • 10,865 Answers
You can continue to run it. it may correct or else it will get worse.......then u can get back and i will help u decide what to do
Posted on Jun 24, 2009
  • 1 more comment
  • Joe Hogan Jun 24, 2009
    you can continue to run it. it may correct or else it will get worse.......then u can get back and i will help u decide what to do
  • witmer259 Oct 07, 2010
    hey justaskjoe .... that was a crappy answer....why should they live with the noise if it can be fixed...
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Our Quiet Series 300 Maytag Dishwasher is LOUD
    few things move on these but the jets and the discharge pump. Are there rotating jets that are removable, if so remove them and clean them it might just be dirt. if you cant find the fault then yes! a repair man could sort it out.
    Jan 10, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
    Loud noise
    Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
    Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    Maytag dishwasher legacy 300 quiet series
    Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
    Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
    The IRONY of my Quiet Guard!! SO LOUD!!!!
    Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
    Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
    Maytag quiet series 300
    Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
    Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
    1 week after installation- is very loud
    dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
    Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
    Dishwashers Logo
    131 people viewed this question
    Top Dishwashers Experts
    Marvin
    Marvin
