Question about Astoria Argenta SAE-2 Espresso Machine
Why safety level on the display - Astoria Argenta SAE-2 Espresso Machine
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
What does the alarm symbol mean on Delonghi portable ac on pacan125hpec
The appliance has a self diagnosis system to identify a number of malfunctions. Error messages (!) are displayed on the appliance display. If (Lt) is written it means low temperature; the appliance is fitted with a frost protection device to avoid excessive formation of ice. The appliance starts up again automatically when the defrosting process is completed.If (Pf) is written it means probe failure; If this is displayed, contact your local authorized service center.If (HL) is written it mean high level; the internal tray is full and you should empty the internal safety tank, however if it pops so often, contact the service center.
Aug 21, 2016 | DeLonghi Heating & Cooling
What is a flashing F23 Error
blank.gif F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Nov 12, 2014 | Whirlpool Duet Steam WFW9700V Front Load...
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
MY HEATER STAR RUNNING AND AFTER A MINUTE STOPS
These appliances are equipped with safety switches to protect against overheating and fires. Check that it is level and not tilted. The fan must also be operational. Based on the limited information provided, I can only offer these suggestions.
Dec 06, 2013 | Heating & Cooling
Does not shut off and the safety valve went off
Your problem dependents on when the safety valve is opening. If the safety valve is opening before the tank reaches its rated high pressure level, usually 130 to 150 psi, the spring in the valve is weak or broken; replace the safety valve. If the tank pressure is going over the rated high pressure level, the pressure switch isn't turning the motor off when it should; replace the pressure swtich.
Nov 25, 2012 | Stanley Air Tools & Compressors
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Astoria Argenta SAE-2 Espresso Machine Logo
13 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
noel
noel
J.D. Browning
J.D. Browning
Kolbrun...
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
