Question about Hyundai HHD1250 1250W Portable Heavy Duty Generator
Why hyundai generator will start no power a ?
Where can i get spare parts for a hyundai hy3000si generator [ie] voltage regulator
voltage output readings are governed by rpms of the motor
check that the engine rpms are correct by adjusting the governor setting
contact hyundai generator service center for parts
Jul 23, 2016 | Electrical Supplies
Where is the ECM fuse and Fuel pump relay on a 2000 Hyundai Tiberon?
images for Where is the ECM fuse and Fuel pump ..
ECU fuse keeps blowing - New Tiburon Forum : Hyundai Tiburon ...
www.newtiburon.com/.../tiburon.../217243-ecu-fuse-keeps-blowing.html
Sep 8, 2012 - 18 posts - ‎8 authors
Edit: Instead, pull the fuel pump relay, and see if the fuse still blows when ... ControlRelay, Fuel Pump relay, A/T control relay, Generator, ECM ... Official "Check Engine Light" Thread - New Tiburon Forum ...
Jul 22, 2014
Fuel pump Relay
Apr 26, 2013
Starting problem. Fuel pump doesn't prime with key on.
Mar 9, 2013
Fuel pump not starting intermittently
Oct 6, 2010
More results from www.newtiburon.com
Car Cranks But Will Not Start - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...2000.../85246-car-cranks-but-will-not-start...
Jan 17, 2008 - 10 posts - ‎6 authors
Jan 06, 2016 | Hyundai Cars & Trucks
How do I check the timing on HY2000si
Check to be sure the "economy" switch connections are properly connected.
Oct 19, 2014 | Hyundai Portable Generator: 2000-Watt...
Hy2000si will only idle
Look at the "economy mode" switch connections. It sounds like the switch may either be malfunctioning or the wires may have come off.
Oct 18, 2014 | Hyundai HY2000si 2000W Portable Inverter
No power
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 19, 2014 | Hyundai HY1000si 1000W Portable Inverter...
How to replace speedometer
you can't they are all sealed units, you can but a use one from a junk yard and change the entire panel or get a replacement OEM not cheap
they are seal for a reason, trying to take apart will most likely ruin what you have...
Mar 10, 2014 | Hyundai Accent Mold - generator terminal....
How do I detach motor from generator
This will slide off very easy when you have all of the fasteners out. Look for a snap ring or a spring pin holding the shaft in. Easy to overlook
Jan 11, 2014 | Hyundai 1250w 2.4hp portable generator
Hyundai 3500 generator carb adjustment
Go to the Hyundai website and ask for the user's manual.. They should have it as a download!
Dec 24, 2012 | Hyundai HHD3500 3500-Watt 4-Stoke Portable...
I Have A 2000 Hyundai Accent And The Codes P1529 and P0722 Came Up. What Does This Mean. Please Help Me Out.
P1529 - MIL light request
P0722 - Transmission Pulse Generator B. The Pulse Generator detects the revolution of the idler gear parking pawl lock gear and emits a pulse signal. The pulse signal is sent to the Transmission Control Module (TCM) which converts it into vehicle speed. The code is detected when the Pulse Generator B failed to provide a signal to the TCM upon initial movement of vehicle.
Symptoms:
- Engine Light On (or Service Engine Soon Warning Light)
- Speedometer improper reading
- Possible shifting problems
Possible Causes:
- Pulse Generator B harness or connectors
- Pulse Generator B circuit is open or shorted
- Pulse Generator B
Jan 15, 2011 | 2002 Hyundai Accent
Hyundai HHD1250 1250W Portable Heavy Duty Generator Logo
Top Hyundai Electrical Supplies Experts
john h
fred_therese
Are you a Hyundai Electrical Supply Expert? Answer questions, earn points and help others
