Question about Epson Computers & Internet
When printer is on but can't do any proccess than what i do?
My pinter is on it's power light,page light,drop light all are on .it's scanner and print can't work than what can i do?
    New Friend:
  • 36 Answers
You need to click on 'control panel' and find 'fax and printers'. If your printer is listed designate it as the primary printer. (make sure it's even listed....and you have the drivers for the printer name and model)
Posted on May 11, 2014
Toshiba studio 350 network printer setup
I can send you the Networking Manual if you send an email to LBrown18062@hotmail.com. Please put 'Toshiba e350 network' as the subject or you can go to the link that I have included here. http://www.eid.toshiba.com.au/Downloads/manuals/230-280_350-450_3511-4511/eS230_350_3511_NetworkAdminGuide_Ver.00.pdf
Jan 27, 2012 | Toshiba e-Studio 350 Copier
How do I get mt Epson Stylus SX425W printer to work wireless? I believe I have added printer correctly. Can only get pinter to operate if plugged into electric. No instructions on how to operate...
All that needs to be done is to install the drivers for your printer using the disk provided from Epson.
Then enable wireless/WIFI on both your computer and your Printer. Usually done with a button on the printer. Blue light shows it is enabled.
Then click control panel.
Right click on the Epson Printer and select to set it as default.
Now right click on this printer and select properties.
Print a test page, the button is found on the bottom right of the screen.
damnor01
Apr 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Why does my HP 1500 prints a test page every time I begin touse it???
HI
As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
After That press scan on the printer button panel it will resolve your issue.
Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
) Lift the lid of the product.
2) Place the top of alignment page face down in the right front corner of the glass.
3) Place the alignment page face down
4) Close the lid.
5) Press the Start Scan button.
6) The Power button light will blink during the alignment process.
7) After the Power button light stops blinking, alignment is complete.
Aug 04, 2010 | HP Office Equipment & Supplies
My hp psc 1315 is not printing all the information from Excel spreadsheet. It appears to be dropping off information. Is this a printer problem or an excel problem
Have you looked at the pinter preview to see if the information is on there before you print. If the info has dropped off befor you print, this could be due to the wrong format size of the paper. Sometimes the printer prints out two sheets which you put side by side for full view.
Jul 12, 2010 | HP PSC 1315 All-In-One InkJet Printer
RE: HP 2110 all-in-one printer. I have put in a new Black HP toner cartridge (color is OK). The printer then goes through the "Align Print Cartridges" process. After the cover page (which prints...
Turn off the printer
Clean the Scanner Glass with Lint Free Cloth ( drop 2-3 drops of water on Cloth, Squeeze it and Wipe the Scanner Glass.
Also try to switch/change the Wallsock/Surge protector socket since the Scanner bulbs are not getting enough power to scan the page
Jun 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
Steps
Thanks
Rizwan
Dec 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
1320 not printing all the time
Your USB cord may be too long, or you have too many USB devices running. Try removing any other USB device, except the printer and do a test print.
Nov 17, 2008 | HP LaserJet 1320 Printer
The copy function prints a solid black page?
Do you see the light going all the way across? The printer may be having power issues. You should make sure it is plugged into the wall and not into a surge protector or a power strip.
If the light is not coming on then there is an issue with the scanner bulb and if the printer is plugged into the wall then you should call hp and see if you can have it replaced.
Jan 21, 2008 | HP Photosmart C4280 Aio Printer
Printer keeps printing picture of the actual printer
This sounds like your pinter is printing a self-test page every so often. Could be a lil' glitch in the printer. Try resetting your printer: 1. disconnect all the cables from it. 2. hold down the large GO button and plug in only the power cord. 3. Keep holding it until the lights start cycling or for 25 seconds, whichever comes first, then let go. The printer should go back into the ready state. 4. Reconnect the printer cable and restart the pc the re-establish communication. If that didn't help, it might have some malfunctioning component and requires a technician to troubleshoot! Regards, babb
Apr 30, 2007 | HP LaserJet 1100 Printer
Computers & Internet Logo
47 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
