Question about LG Heating & Cooling
Error ch 21 - LG Heating & Cooling
    Master:
  • 398 Answers
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Delray Beach
Posted on Aug 15, 2016
Film fast fowards 12 frames at a time. what could be the problem? it has a mb-21.
12 frames, in how long of a span? When you're first loading, or when you're holding down the shutter release?
The high-speed winder has a speed of about 5.7FPS when in Ch mode, if that's the issue, just rotate the dial on top from Ch, to S. If it's something else, please clarify. There's a small button next to the dial you'll need to disengage the lock.
It's got S(ingle) Ch (high speed continuous) Cl (Nornal continuous) Cs ("Silent" continuous) and Self Timer.
Jul 05, 2011 | Nikon F4s 35mm SLR Camera
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Searching parts
try prs eletronics components uk.
Oct 12, 2009 | Gateway FPD2185W 21 in. LCD Television
Error on the machine display is ch
If the CH is blinking the cartridge is not installed correctly. Remove and reinstall cartridge.
If the CH is on constant, it is a sorter problem. Check sorter for paper jam or bins out of place, and sorter connection.
Hope this helps.
Ed
May 18, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
CH Error
CH means your toner cartridge is needing replaced.
Feb 25, 2008 | Sharp AL-1551CS Printer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Heating & Cooling Logo
231 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
