Technika troubleshooting how can I go about fixing pink lines on my technka television, The lines are constant and then the full picture begins to go light pink and becomes impossible to use?
Is there anything I can do to try and fix this problem on my own as I would not be able to afford to fix it myself
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
I doubt you will be able to fix that problem yourself since its a modulation out of sync in a device which I'm familiar with, but I forgot the technical name. Usually all TV's will sooner or later have that problem with age. It's good money down the drain, because once a TV has picture problem of such it inherently causes other problems. The device is made of many adjustable rheostats which takes time tuning (color mixtures).
You'll never get it back to factory specs. Best to forget about it and buy a new TV, a word from someone who's gone through the hassle more than once. Besides if your TV is more than 10 years old, the part will no longer be stocked or available.
Posted on May 10, 2014
  • 6 Answers
SOURCE: Haier 42 inch plasma
Many of the issues with this hunk of junk can be fixed by Sears through a "3 cards and a chip" upgrade - Sears will order the parts for you after they come out and see that sure enough, your monitor hasn't been upgraded (after the upgrade is completed, a sticker is placed on the monitor) which you most likely haven't had done. The chip will fix the problems you're having. I claimed this as "manufacturers issue" with Sears, since they know about the problems with these monitors and they did the work for free. The parts need to be ordered by their tech rep, then they are sent to your house, with instructions and if you're a little handy you can install everything yourself.
Posted on Jul 08, 2007
SOURCE: my samsung television (hd ready) has developed a
Check the color settings in the menu. It has white balance and color correction that can be adjusted by hand. If you don't know how to adjust the color balance, just reset the color settings or choose a preset color selection (Dynamic, Movie or Normal).
Posted on Jan 12, 2010
  • 10 Answers
SOURCE: tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Posted on Apr 15, 2010
toolkits
  • 1099 Answers
SOURCE: I have a 5 yr old Samsung HP-R5012 Plasma Display
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 11, 2010
SOURCE: My name is David and the problem with my TV is
It sounds like the lamp might be bad. The lamp lights up the screen from behind, so without the light you can see shapes moving but they are very dark.
Posted on Mar 05, 2011
Technika tv screen goes pink when plugged into laptop movie
try reseting the laptop when the tv is plugged
Apr 24, 2014 | Televison & Video
I have a 2004 1080 HD Mitsubishi TV that has pink lines running across the picture.. How can I fix this.
Pink lines can mean many things, what does the set look like if you take it in the customer menu and select convergence and then advanced?
The more you tell me the better I can help. Post a comment here to let me know
SD TECH
Aug 23, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
May 18, 2010 | Televison & Video
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Pink and green lines and double picture on Samsung big screen tv.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Jul 08, 2009 | Samsung LN40A650A LCD TV
Sylvania 6842, bars in picture
The service manual troubleshooting procedure says to replace the control circuit board and if that doesnt fix it to replace the display panel.
Oct 27, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
When sound & picture finally comes on the picture is pink and in the middle of the screen
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the no audio/video and video shrinking problem.
Sep 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
COLOR PROBLEM
Is the pic full? Or is this pink square full and the pic seem squeed?
Jan 03, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
