Question about V-Fit Htr2 Dual Hydraulic Sculling Rower
V fit user manual
I have put the battery in but how do I set up the digital monitor . In what order do I enter the numbers and what do they relate to. What is displayed
How to insert sim card in phone? and which card insert micro sim card or full sim card?
Depends on what phone as to what size. Most phones have the sim card under the back cover....some are under the battery. A few have a small door on either side of the phone. It should be relatively obvious as to which one will fit once you see the sim port.
Jul 18, 2016 | Cell Phones
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
I just received my watch. There was no manual. I thought the time was set by radio in the middle of the night. It is not set at all. It does not work. Does it need a battery? What do I do? ...
These watches do set themselves during the night. The watch come with a battery fitted so this should not be your problem.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jan 05, 2011 | Casio Gents # Mtr 303 1AV Watch
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
No signal
You don't specify what kind of monitor, CRT, LCD, or even a TV attached to your system, you're using. It's likely the monitor is set to receive a certain kind of signal (either analog or digital) but it's receiving the other one instead. Before proceeding to the next steps, ensure the connections are solid and the the screws are set tightly and there's no movement.
Get your user's manual and learn how to navigate the monitor's menu in order to get to the setting where you choose Analog (for a VGA cable connection) or more commonly with LCD screens, Digital (DVI).
VGA and DVI connectors differ in shape and in the number and layout of their pins. If you're using a video card with a DVI connector (larger, more squarish D shape, with three separate sections of pins) then your monitor shoud be set to Digital. Else, your connector is VGA and thus your monitor should be set to Analog.
If both are in synch and you still do not get a signal, it's possible the video card has given out its ghost, since if you DO see the NO SIGNAL message displayed on your monitor, the monitor is Ok.
Aug 17, 2009 | ViewSonic Computers & Internet
There seems to be no option to activate speed dial. I have read the user manual and would like to think I'm not this stupid. Also it seems that I can only have 5 ring tones AND I can only use them for the...
To get a form of speed dial and caller ID to work, ones must have all contacts entered into the phones storage AND sim storage. Order of contact entry is in direct relation to the "speed dial" numbers. Then on phones menu screen, hit DIAL, and then a 1-3 digit number followed by the # sign. Another screen will come up with contact name and phone number that resides at the number you entered. There will be two pictures of phone receivers numbered 1&2. Push which ever one for the sims you have activated and your call will be made. It is almost just as easy to simply remember the number for the person who is so important to call so quickly. For caller ID-contacts in both phone and sim storage AND the number MUST BE ENTIRE #. This means area code, international code, etc. No solution for the lack of ringtones that can be USED at a time. Possibly if one can delete out set tones by accessing the phones engeneering or factory mode by entering in the required codes, the lame tones could be replaced by your desired ones. All info from http://home.comcast.net/~plutarch/Sciphone-i68.html
Jul 31, 2009 | Cell Phones
My husband messed with the tension setting on my kenmore sewing machine. (I got it from a friend so it's older, but new to me.) Is there anyway to change it back to the manufacturers setting?
You should be able to order an owner's manual from the Sears parts site.
Just enter your full model number at their site.
A full Sears/Kenmore model number normally has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Dec 20, 2008 | Microwave Ovens
Setting time
To get the manual from the Reebok site, you need to know the model number (not 10M). The Reebok site says you can look on your user manual for this ?!?. If I had my user manual, why would I be online looking to download a user manual?
Anyway, there is another response below that answered my question.....
You have to hold down the mode button until the time starts flashing, hit the mode button again to get hours. Adjust with the stop/start button.
Hope that helps...
Aug 30, 2008 | Reebok Fit Watch 10M Strapless Heart Rate...
Date and time settings
The date battery needs to be replaced. It is a coin-type battery, CR1220. It fits in a holder that slides out from the bottom of the camera, opposite the side from the battery cover for the regular batteries. When putting the new battery in the holder, the negative side of the battery should be visible. Illustrated instructions are on page 87 of the Advanced User Guide.
Jul 26, 2008 | Canon PowerShot A410 Digital Camera
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
V-Fit Htr2 Dual Hydraulic Sculling Rower Logo
77 people viewed this question
Top V-Fit Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a V-Fit Exercise and Fitnes Expert? Answer questions, earn points and help others
