Question about Minolta Office Equipment & Supplies
Service code c223 - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,161 Answers
ON what model sir/mam? it there a "0" missing?
Posted on Dec 29, 2014
Where is the engine oil dipstck ?
Always at the front of the engine, always attached to a tube that goes into the engine block. These days, always a yellow ring on top. The image is a genuine Isuzu part.
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0996b43f/80/23/0d/f9/medium/0996b43f80230df9.gif
Nov 10, 2015 | 1983 Isuzu Pickup
Engine running rich
which country?
which engine of them many?
EFI or CARB?
wiki this, see the line up for engines..????
nobody can guess this,
1.6 L G161Z I4 (gasoline)
1.6 L 4ZA1 I4 (gasoline)
1.8 L G180Z I4 (gasoline)
1.8 L 4ZB1 I4 (gasoline)
2.0 L G200Z I4 (gasoline)
2.3 L 4ZD1 I4 (gasoline)
2.0 L C190 I4 (diesel)
2.2 L C223 I4 (diesel)
Aug 09, 2014 | 1990 Isuzu Pickup
Modulator valve location
to what? transmission or is the EGR mod or?
what year, trooper.
and what engine.
modulator means zero.
the injectors are modulators, the ISC is, and many other parts.
the car has systems. name just one,
2.0 L G200 I4 (UBS13)
2.3 L 4ZD1 I4 (UBS16)
2.6 L 4ZE1 I4(UBS17)
2.2 L C223 diesel/turbodiesel I4(UBS52)
2.8 L 4JB1 diesel I4
2.8 L 4JB1-T turbodiesel I4
2.8 L LH7 V6
2.8 L LL2 V6
3.2 L 6VD1 SOHC V6
3.2 L 6VD1 DOHC V6
3.5 L 6VE1 DOHC V6
3.0 L 4JX1 TD I4
3.1 L 4JG2 TD I4 and many transmission, the body is a shell, the drive line is all optional.
Jul 12, 2014 | Isuzu Trooper Cars & Trucks
Izusu timing marks diagram
double posted,
year,
spark or cam?
KB tells PICKUP of many kinds and engine and years.
pray tell which one.
hark
if gas, you have spark and cam timiing.
which is it.
and what engine.
we can not guess any of this... ever.
Mar 27, 2014 | Isuzu Cars & Trucks
I have sound but no picture, over the last month it has been taking an hour to get sound and picture from switch on, but today it is just sound after about 2 hours. 15PF4121/05
Similar problem in my Philips. No picture, just green led flashing in front panel. Reason was dried up capacitors in power supply card. Came on by renewing c223 and c228.
Jan 18, 2010 | Philips 15PF4121 15 in. LCD Television
Cruise control for 1994 mercury sable four door sedan not working
There are numerous things that can cause this. A fuse, a vacuum leak, a bad switch in the steering column. The switch in the steering column is usually the culprit but is also the hardest and most expensive to change. Best way to find out is to plug it into a computer and see if it reveals any trouble codes.
Also of the many things that can go wrong outside of replacing the servo controller.
Check the servo deactivation switch. Located on the brake pedal arm under he dash. This will require you to remove the black plastic duct fot shield to expose the under dash area. It only has 4 plastic speed grommets. You will see to switches on this brake arm.
The lower one activates the brake lights. The upper one deactivates the cruise control and is a common failure in 1998-2002 Ford mercury Crown Vics and Marquis. Remove the connector(also known as connector c223), and check the continuity of the switch opened or closed. It should change from infinite to a short using a standard voltage meter set to ohms or continuity and pushing the brake pedal.
Also Fuse number 1 (15amp blue fuse) located there under the dash as well, is the primary fuse for the cruise control servo. In most cases you will see this ok
Sep 08, 2009 | 1994 Mercury Sable
Isuzu C223 Diesel, steering pump pulley removal.
alot of times they are pressed on requires a special removal tool
May 10, 2009 | 1997 Isuzu Trooper
Isuzu C223 timing
need a injector pump dial indicator to set up lift in pump (movement on dial indicator)0.05mm at correct timing mark on crank pulley 12 deg.
the above is an example for 4JB1 & 4JB1-TC
which are isuzu diesel engines
Apr 19, 2009 | 1988 Isuzu Trooper 2 Door
KDS Silver 17 inch monitor
Hi again,
Am not sure what happened but I lost you in the Chat/Live Session. For a while I saw you typing a message ... and then it would appear that for some reason, the session was ended.
With your indulgence, I would post the additional steps:
  • If the LCD is receiving power, then probable faults could be the main board that processes the video and controls, the CCF (cold cathode lamps and/or inverter. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional;
  • If you are considering a DIY, the unit has to be opened up and the fault determined. In most cases, it is the inverter. This could actually be verified by running the LCD monitor and let the PC boot even if not visible. You could try shining a lflashlight at an angle on the display and see if there is a semblance of your desktop except that it would be very dark. If yes then it is possibly the CCF lamps or most likely the inverter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 30, 2008 | KDS 17S 17" Monitor
13 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
