Question about Star Micronics SP700 Receipt Printer
How to reset star so700r machine - Star Micronics SP700 Receipt Printer
HOW DO I RESET MY panasonic kx-fl422 FAX JX200 TO FACTORY DEFAULT
Press "Menu" STAR, #, 9000,STAR, 550, START, then restart the machine.
Aug 04, 2015 | Panasonic Office Equipment & Supplies
Service l6 10
Sharp AR-M207 . Enter these keys one after the other to reset:
  1. # - * - C - *(pound, star, C, star).
  2. The screen will go blank and ask you to enter a code
  3. Enter "14" and press the print button.
  4. It comes back and asks if you are sure(showing "1" as default). Press enter.
  5. Machine should then reset
Aug 21, 2013 | Sharp AR-275 Copier
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Sep 20, 2010 | Sharp AR-275 Copier
My Sharp AR-M205 Copier has developed a problem. The code L6 is flashing up on the Display panel. Someone suggested I might be able to fix it by 'resetting' the machine. Can anyone advise how precisely to...
L6 is polygon motor lock (in the laser unit). To try and reset on the keypad press P * C * (pound star clear star) and enter sim 14 and press copy button. the machine should restart if down right. If the code comes back the LSU unit will need to be replaced. Should be done by a trained tech.
Aug 25, 2010 | Sharp AR-M205 Copier
I have a fax machine panasonic kx-fl422 bring on call service 3
Apr 14, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
When on spin cycle, the washing machine dances across the floor.
Try to level machine. Whe empty try to reset back legs pulling machine from rear up front leaning on front legs. Try to balance your load too.
Dec 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Toshiba E-studio 166
if you turn off the machine and then turn it back on whilst holding down the 1 3 and star button all together it shoul reset any small errors you have on the machine.. good luck A
Jun 22, 2009 | Toshiba e-Studio163 Copier
Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Jul 20, 2008 | Sharp AR-BC260 Color Copier
Star Micronics SP700 Receipt Printer Logo
63 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
