Question about Asko 24 in. D3350 Dishwasher
F4 flashing on asko front loader W6222 - Asko 24 in. D3350 Dishwasher
5 Suggested Answers
SOURCE: how do you remove the agitators on the asko w6222
dont be afraid to use pressure and lean the screw driver to the left as you pull down on the agitator goodluck
Posted on Aug 07, 2010
sonicboomele
  • 1557 Answers
SOURCE: Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Posted on Jan 04, 2011
  • 403 Answers
SOURCE: I have an f3 and
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Posted on Feb 14, 2011
  • 45431 Answers
SOURCE: Asko washing machine w6222 front loader will not start, I checked the drain at bottom and appears clear
sounds like your water inlet valve has failed .
Posted on Jun 25, 2016
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
Jun 20, 2012 | Asko W6222 Top Load Washer
Jan 04, 2011 | Asko W6222 Top Load Washer
How do you remove the agitators on the asko w6222 front loader(not the "use and care guide" book respose please)
Apr 08, 2010 | Asko W6222 Top Load Washer
Asko 24 in. D3350 Dishwasher Logo
35 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
