Nec aterm wl11cb wireless lan card - Computers & Internet
5 Suggested Answers
mail2pvs
  • 390 Answers
SOURCE: turn on radio button of my wifi NEC VersaProVA11J Laptop.Please H
two things you may wanna check
if the wireless is enabled in your network settings
and 2nd may be there is a Fn key +some other key combination for the wireless
Posted on Jul 24, 2009
  • 4044 Answers
SOURCE: i cannot set up wireless net- windows xp, wireless
Try setting the router to DHCP and use channel 10 instead of channel 6 to broadcast your network ID. Also, make sure you are using the correct WEP key if you have it set to use one. In Windows set the network to get the IP address using DHCP. If you have local only when you view the network double check with your ISP to make sure you have teh proper settings for the router to work with the network.
Posted on Sep 23, 2009
SOURCE: Can you please tell where
No luck,
The Wimax modem you are trying to get a manual for is only currently being widely used in Japan I believe.
It's a good unit and pretty easy to set up even if you don't read Japanese. The easiest way is to make sure there are no other wi-fi networks around and then access it via wifi. Most modern operating systems will automatically detect it and you'll need to enter in the AES password on the back of the unit wear it says (AES) lots of spaces than colon than the password. Or if you try to access it on a portable device you may have to enter in the WEP password. (there will be two networks autodetected probably and each network is a different type and has a respective password)
Once you have done this you still won't have internet. You have to type in http://web.setup/ in the internet browser of the device you are using. If nothing happens try the other network with the other password above. If still nothing happens then try entering http://192.168.0.1/
Once you have successfully done this you'll be prompted to put in a user name an password. Use the user name "admin" with some password several times until you get prompted to enter a new one and then again below.
You'll need a Japanese friend to help you with the rest.
Good luck
(and it's better to not use an iphone/ipad etc.. or you may end up in a weird refresh loop (if this happens close the window in safari and exit and try again with "admin" and your new password.)
Posted on Sep 11, 2011
SOURCE: I need drivers for display, lan and wireless lan for NEC-LS150F2P2W LAVIE....help please
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.
Posted on Apr 02, 2012
What Wireless usb LAN Module will work with nec projector ?
It looks like a common B/G/N adapter will work fine with the projector as stated on the website. what is the model of your nec projector?
Sep 02, 2014 | Computers & Internet
My notebook NEC versapro VA75h doesn't have lan port and I need to connect with lan jack
You can solve this problem by buying USB to RJ45 Converter like this oneor RJ45 PCMCIA Card like this.Good luck!
Dec 23, 2011 | Computers & Internet
Cannot find download driver for vista Aterm WL54AG
Here's an easy way to install or update your Aterm driver:
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve them for you.
You can download this free tool from here or directly from this link
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XP Drivers .
Mar 24, 2010 | NEC Aterm WL54AG (PAWL54AG) Wireless...
I cannot set up wireless net- windows xp, wireless aterm wl54ag warpstar card, i did downloaded driver but routine setting up connection simple doesnt work,
Sep 23, 2009 | NEC Aterm WL54AG (PAWL54AG) Wireless...
Turn on radio button of my wifi NEC VersaProVA11J Laptop.Please H
Jul 24, 2009 | Computers & Internet
Looking for English instruction on setup of NEC Aterm WR7850S
download translator program that can translate japanese to english language. good luck
May 04, 2009 | Computers & Internet
Can't find wireless Signal
Make sure her router is configured to broadcast the SSID as that can either be disabled or enabled. Once thats enabled and you still cant see it try and set it to different wireless channels and change the wireless network mode to 'mix"
Jan 03, 2009 | HP Pavilion dv6000z Notebook
NEC Versa s970
when the bluetooth and wlan light are off press the wireless button three times and wait a sec and it will work. thats what nec told me
Apr 16, 2008 | NEC Versa LX Notebook
MobilePro 900 turn on during the night and not shut back off
Devices running Windows CE 3.0 turn on at midnight to search for appointments for the coming day. Reminders are set and the Today view is updated with the day's events. The device is supposed to turn off after three minutes of inactivity. If a program is running the unit may not turn off because there is activity. The following applications are known to cause problems: * Windows Media player for Pocket PC. * Active Sync * Wireless LAN adaptors NEC has developed a registry patch that has been tested on the following LAN cards. Device Vendor Driver Cisco Aironet 340 Cisco 2.30.11 Cisco Aironet 350 Cisco 2.30.11 Linksys WPC11 Ver 3 Linksys 1.07.29 Orinoco Orinoco 1.02 3CRWE737A 3 Com 2.2.5.0 LA4137 Wireless Network Symbol N/A For additional information see Microsoft Knowledge Base Article – 263719 Click here to download the Power Management update utility. Installation procedure. Note: Anytime a “hard reset” is performed on the MobilePro 900 the Power Management update utility needs to be re-applied. 1. Download the Power Management update utility to local system. 2. Copy the Pwr_Mgt.exe file to the MobilePro 900 desktop. 3. Double tap the NEC Icon. 4. Click OK. 5. With power on momentary depress the “soft reset” on the bottom using the stylus. 6. Delete the NEC Icon on the desktop.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
