Question about IBM UltraStar 9ES 4.5 GB Hard Drive
DDRS-34560 HD need to know settings on hd for master, slave, etc.
  • 328 Answers
Here is all the info you need.
Posted on Nov 04, 2007
How do i make a wd5000aakx hard drive a slave drive
Jul 11, 2015 | Conrad WD HDD 500GB SATA 3,5" WD5000AAKS...
PC does not detect HD after installing CD ROM
I assume that both are on the same cable. You need to check the jumper on your CD ROM and make sure its set to 'slave'. The HD is usually set to "master".
Let me know if you have any further questions. Thanks.
Sep 17, 2010 | Computers & Internet
you may have not properly set the jumpers on your new installed hard drive.
usually a computer will have 2 eide drive controllers where you would connect a ribbon cable. a ribbon cable has a middle connector and end connector and obviously another end connector that connects to the motherboard)
now you can connect upto to devices to that ribbon cable. most computers will have one device connected to the end connector (the hard drive) and no devices connected to the middle connector or sometimes they may have 2 device on the same cable: the hard drive on the end and a cd/dvd drive on the middle. others computers may have one ribbon cable for each device as computers usually come with 2 drive controllers (so you can connect 2 cables which means a total of upto 4 eide devices)
now, when you connect devices on 1 ribbon cable, the end device is the master device, the one the middle is the slave. to make a device a master or a slave you need to set a jumper. the jumper is usually located in between the ribbon cable connector and the power connector, the legend to know where the jumper goes to make it a slave or a master is usually on the label of the hard drive. you may need to check that label and with some pliers make the proper setting for that jumper.
on a new hd usually the jumper setting will be in master. so if you connected the hard drive on a ribbon cable that already has a master at the end it may not be detected. try to connect that master device on another ribbon cable that has no other devices connected and connect it on the end connector (not the middle one). if you have no other option but to connect it in the middle already having a master device at the end, set the jumper to on the slave position.
while you are at it. make sure you have your power connector and data (ribbon) cable properly seated.
if the caviar hd your are trying to install is an old hd and you know that you have the proper hd configuration and the cables properly seated, it is possible that no detection means hd failure.
Apr 04, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Setting Maxtor HD as Slave.
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Ibm ddrs-34560 ? mettre en slave
This is a SCSI drive. You need to set an ID using jumpers as shown here
Feb 23, 2008 | IBM UltraStar 9ES 4.5 GB Hard Drive
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Cannot boot in Slave mode
i have never heared of any hardrive being able to boot when it is set as slave, as the master is always the 'C' drive from which windows looks for the master boot record. why, if you have only one hard drive is it set as slave?, it doesnt make sense. No hard drive will boot up if there is no jumper cap on it, as the motherboard needs to know which hd is master and has the o.s on it.
Jul 28, 2007 | Asrock P4I45GV R5 Motherboard
Open Questions:
See all IBM UltraStar 9ES 4.5 GB Hard Drive Questions
IBM UltraStar 9ES 4.5 GB Hard Drive Logo
149 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
