Question about Dell Inspiron 1720 Notebook
My inspiron will not come on with ac power and no battery. just blinks 3 blue lights one time and does not come on. what is it???
Wont come on
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Posted on Jul 14, 2008
Pyrhyc
  • 2028 Answers
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
  • 40 Answers
SOURCE: orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Posted on Jan 24, 2009
El Geek
  • 149 Answers
SOURCE: Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Posted on Jun 02, 2009
mbostermeyer
  • 58 Answers
SOURCE: The blue and amber light flashing on the battery indicator
You should talk to a Dell support specialist. The blinks are actually a code that tells you exactly what is wrong with it.
Posted on Oct 24, 2009
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
Hp dv 2500 mb-ct:P74511B2DV33T2 p/n GS846UA#ABA s/n 2CE7380QWD Laptop wont boot Lightning led flashes three times with or with out battery. Have done hard reset. Battery wont charge,blue power input...
My HP flashes 3 times when my battery is dead. Because of this I'm guessing that the AC Adapter is not working properly because it should turn on even with the battery out as long as it's plugged in. Many power adapters have a light on the actual converter box, you want to take a look for that light. If it is on, there is a problem with the cable and/or the connections between that box and the computer. If it is off, try another outlet. If you've done all this troubleshooting I would probably recommend getting a replacement AC Adapter. They are specific to the computer so make sure you purchase the correct one. Last time I replaced one the cheapest I found one (Dell Inspiron 1525) was @ Amazon.com
May 05, 2011 | Computers & Internet
I have a Dell Inspiron mini 10 . net book. Out of now where said something about windows and shut off ... now we cant get it to turn on, wont go past the inspiron load screen the little blue only goes...
tryt to do this
1.unplug the ac adapter
2.remove the battery
3.press the power for 30 secs
4.plug the ac adapter back in and after few secs try to turn it on
Oct 04, 2010 | Dell Inspiron Mini 10 Notebook
My laptop wont turn on. i also doesn't blink 3 times when i press the power button with the ac adapter plugged in. i tried taking off the battery and holding the power button on for 1 minute but that still...
Does the blue light come on at the side where you plug your ac adaptor in? If it does, and your laptop still wont turn on, its likely you have a motherboard failure. Also try this without the battery inside. If the light is not coming on the charger port at the side, then its most definitely your ac adaptor at fault.
Jul 22, 2010 | HP Pavilion dv9700t Notebook PC
My dell inspiron 9100 wont start the operating system and the little light with the A in the middle blinks and then turns off can u help me?
Remove the battery the ac adapter,the memory.the hard drive and the cd rom.Press and hold the power button down for twenty seconds.Replace the memory first then the battery and the ac ,power up if this works add the other pieces one by one.REMEMBER BEFORE YOU ADD EACH PIECE THERE MUST BE NO POWER ,NO BATTERY OR AC ADAPTER.
Good luck
Nov 14, 2009 | Dell Inspiron 9100 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 9300 wont power up/good battery and charger
check if your systemboar power is on or not, and also check if the fan is spinning or not. If not try and reset your processor.
Apr 20, 2009 | Dell Inspiron 9300 Notebook
Dead inspiron 8600
take out the battery and use the AC.
if that power up the laptop. then the battery is draining the power source. if not, the laptop power citcuit need to be check out, which I think should be done a repair shop.
Dec 01, 2008 | Computers & Internet
Laptop won't turn on
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 1720 Notebook Logo
18 people viewed this question
Alun Cox
