Question about Raymarine Ray218 Vhf Radio
Transmitting and Receiving fault
My Ray218 VHF radio won't transmit or receive is the unit U/S or can it be fixed with a setting
    Sergeant:
  • 415 Answers
Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Posted on Mar 02, 2015
2 Suggested Answers
  • 64 Answers
SOURCE: I have a one year old Raymarine 218 vhf which has
The main cause for lack of reception or transmit distance is the PL259 connector on the antenna coax that plugs into the back of the VHF. Check to make sure this connector is a high quality, marine grade connector. If it screws on and the coax shield is not soldered to the connector I recommend replacing the connector and soldering it. If the problem still exists I would try a different antenna to see if this is the problem. It is possible that the radio itself has a problem, but check these other issues first. Raymarine has a 3 year warranty on their VHFs so you could send it back for a no charge repair if the antenna doesn't solve your problem.
Posted on Jun 14, 2010
Testimonial: "Thanks for your assistance. I will try your suggestions and see where it leads me."
Yaesu 270 not transmitting nor receiving
Hi this can be down to many reasons, radio keypad locked, receive on tone squelch, set on "Relay" or "Repeater", or even radio failure. Without the radio I cannot help, but that may give you some ideas.
Feb 14, 2015 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
I can't get my ntl twr500 2 way radios to conect to each other
Do you hear anything on one unit when transmitting on the other?
If you do, it will show that the unit is transmitting.
One or both might be set on the wrong channel.
Check both units this way/ Check each to see if they are receiving any signal when the other transmits. Hope it helps.
Tom
Mar 26, 2013 | Cobra microTALK LI 7200-2 WX VP Two Way...
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
I have two motorola aux4100 radios. I can not get them receive. When I key it up to transmit, the red LED of the transmitting unit comes on and the green LED on the receiving unit comes on but does not...
I would guess you have a PL set on the receive side, and not on the Transmit side. So the audio is being blocked by the PL (as it is supposed to be!) Check your programming, make sure you have the same PL on tx and rx.
Jun 03, 2011 | Motorola AUX4100 2-Way Radio
I have a one year old Raymarine 218 vhf which has been transmitting properly however the receiving has been spotty. I can sometimes only get about 1 mile reception. Lately even the one mile reception has a...
Jun 13, 2010 | Raymarine Ray218 Vhf Radio
My customer has 6 motorola max trac vhf radios. all have same problem, they transmit just fine & then they just quit transmitting, they still receive but wont transmit until they turn unit off &...
If this is a new install, it is likely noise from the vehicles electrical system scrambling the processor of the radio. Put a filter on the power leads and check your install.
Aug 26, 2009 | Motorola T9580RS Two Way Radio
Navman VHF 7100 Radio neither receiving nor transmitting
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
Aug 10, 2009 | Navman Tracker 5600 GPS Receiver
Uniden Oceanus not transmitting
You may have a sub-channel/privacy channel activated. Unless the person/s you are trying to talk to have the same channel and code set they will not be able to hear you. Check your manual for specific instructions on how to reset it to the default.
Jun 11, 2009 | Uniden Oceanus DSC Wham ready Fixed Mount...
Raymarine Ray218 Vhf Radio Logo
184 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
