Question about Russell Hobbs Kitchen Appliances - Others
Does russell hobbs have a repair service for classical 2 slice toasters. One element (heating wire) has burnt through, and the whole thing does not want to heat anymore...
Model 18456
Falling Down
  • 67 Answers
SOURCE: Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Posted on Nov 30, 2007
cactus bob
  • 267 Answers
SOURCE: "Outside" heating elements don't heat up. Can I find replacements
its not the elements . its the control board . and you cannot buy a control board , but it can be fixed there is a small relay on the board that needs to resoldered to the printed curcit board . its a pain the the rear-end to get to it , fix it and get back in there and all back together but it can be done ( about 3 hours total ) , if your like me and never say never ......... good luck
Posted on Feb 19, 2009
  • 3 Answers
SOURCE: Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Posted on Mar 28, 2009
SOURCE: Russell Hobbs 9376 Classic 2-Slice Toaster
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
espressonist
  • 1711 Answers
SOURCE: I have a 4 slice
The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook.
So the most frequent problem with elector-magnet is due to the heat some wire or springs become loose so the electro-magnet is not working properly so it does not stay down.
Another reason that electro-magnet not work properly is due to bread remaining does not leave the lector-magnet contacts to contact. You should clean between where the metal of the Electrical contact meet each other.
Posted on Sep 15, 2010
Toaster won't turn off
its broken, retun it to the place you brought it and demand a refund
Nov 22, 2013 | Russell Hobbs 18117 4-Slice Deluxe Toaster...
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Manual for Russell Hobbs breadmaker 4461
Ask the breadmaker manual search engine:
manualfox.com/searchengine/breadmaker.htm
If they find it, they will provide you a direct download link.
Jul 25, 2010 | Russell Hobbs 9209 Classic 4-Slice Toaster
Green wire where does it go
If the connected end is attached to the toast holder and NOT the heating element, then this is a ground wire, and the other end should indeed connect to the case (body) of the toaster.
It may be attached with a screw (typically the screw is also green) or it may be attached to a simple metal tab (on the body) with a notch in the tab to accept/hold the wire.
If this helps, be sure to hit the "thumbs up" for me.
If not, use the "add comment" button and we'll get you sorted out.
Apr 17, 2010 | Russell Hobbs 9376 Classic 2-Slice Toaster
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Require replacement wire which triggers the catch when the operating handle is pushed down. Where can I buy it?.
Russell Hobbs products are firmly placed at the budget end of the market and many of their products have little or no spares availability as they're often not designed to be repaired.
However, they do supply spares for some models if you're unable to fabricate the part yourself, see web address below:-
http://www.russell-hobbs.com/parts.shtml
I hope that you've found my answer to be useful and ask only that you return the favour by rating my answer.
Sep 24, 2009 | Russell Hobbs 9206 Classic Coolwall...
Dec 27, 2008 | Russell Hobbs 9376 Classic 2-Slice Toaster
Neville
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
Kitchen Appliances - Others Logo
48 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
