Question about Saitek Video Game Consoles & Games
Buying spare parts/ screw clamp housing - Saitek Video Game Consoles & Games
The clamp screw has gone missing from my jig saw. can i get a replacement
yes if it was bosch that fits a with a clamp *****
google on the word service, powertools (your Brand) , parts, spares or *.pdf
Bosch Power Tools
Nov 15, 2015 | Saws
How do i remove the Base?
Makita BO4900V Parts Breakdown
Beginning with pos 6 4 screws and remove pos 1 on top 3and4 both carbon brushes with holders . now you can split the armature with base from the motor housing .thats the only thing need for it.
so you can do the job . by replace the armature look for the bearing fits well in the housing again and replace the brush holders etcetera
Oct 28, 2015 | Makita BO4900V Half Sheet Finishing Sander
How do replace radiator hose
As car repairs go, a radiator hose is one of the easier jobs.
Get a replacement hose.
Wait for the engine to be cold.
Loosen the hose clamps at each end of the hose.
Use a heavy screwdriver if needed to loosen the hose from the radiator and engine. Pull the hose off both ends.
Put new hose on, with the clamps. Tighten the clamps.
Fill the radiator with coolant as needed.
done.
Oct 01, 2015 | Cars & Trucks
How do i bypass the heater core on my 2001 gmc jimmy?
Check the heater hose sizes. Buy a connector to put the hoses together and hose clamps. Cut the hoses, insert the connector, and tighten the clamps.
If you just want to stop the coolant flow, go to any parts house and buy either a heater hose shut off valve (cut the hose, insert the valve, and install hose clamps) or buy an external hose shutoff that clamps the hose shut stopping flow.
Jul 10, 2014 | GMC Jimmy Cars & Trucks
Ok i jus buy a ac chek presure manifold, i wanna recharge mi ac carcompresor but the manual donat said how conect tha house in the r134a can, just said how to chek the presur,, can some one help me with...
To connect the hose to the can, it should have a locking ring with a valve. Some connectors screw on clockwise, and others snap on and clamp downward with a locking lever. To open the can, just turn the T valve down clockwise. To release the freon into the hose, turn the valve to the left. Never remove can from the valve assembly, until the can is empty. If you have no clamp and valve for the freon, just a hose, you can buy one at your local auto parts store
Jul 30, 2011 | Mountain R134A Brass Manifold Gauge Set...
My Singer Athena 09 drops the needle when ever the material is heavy. It usually doesn't break it just comes out of the part held by the screw. I need to buy stock in singer needles, as this happens way...
it sounds like the needle clamp screw is not tight enough or is stripped out
some needle clamp screws have a **** where you can put a flat screw driver in to tighten & if that doesn't work then you need to check on getting a new needle clamp screw
Oct 26, 2010 | Singer 8763 Curvy
Needle clamp screw broke off and the end part of the screw is still lodged inside the needle bar. How can I get it out? Would appreciate any help!!
Wow! That's sure a tricky situation! Just had a look at my needle clamp screw set-up through a magnifying glass. It seems to me that there is a very small Allen screw just above the needle clamp screw place. Could you use a small Allen key and undo this, hopefully releasing the whole needle clamp assembly. The cheap kits sold in chain stores for repairing glasses may well contain a tiny Allen key. Your next challenge will be to locate a new needle clamp assembly, but a Husqvarna dealer should be able to help you out there. There is an excellent online place for buying spares but I am very sorry I can't remember its name. Try Google? You could try taking it to a hardware store and seeing if someone there can help you with a suggestion on how to remove the screw shank.
Sep 08, 2010 | Husqvarna Designer I
Whare can I buy spare parts for my Konusmotor 130 telescope?
You cannot buy spare parts-- it's an imported scope. No one carries parts.
However you can but screws and bolts from a well stocked hardware store, and other "standard" accessories like eyepieces from many on-line retailers. Here are two:
http://www.agenaastro.com/
http://shop.telescope-warehouse.com/
Aug 22, 2010 | Konus Optics
The self-closing valve on our 13 year old ST60 speed transducer now only closes sometimes when the blank or impellor sensor is removed. We suspect that a spring is missing. We need a raymarine spare part...
Spring not available must buy housing and replace or if it is sleeved, buy housing and slide in new sleeve there are two different types, one has a removable sleeve with flapper
A long shot would be Raymarine tech support 800-539-5539
I can sell you the part 847-746-0100 technicalmarine.com
Feb 20, 2010 | Raymarine St60 Plus Package, Includes...
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Nov 07, 2008 | Photography
Video Game Consoles & Games Logo
50 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
juanmireles1
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
