Question about Simpson Esprit 750 Top Load 7.5kg
What does E20 mean on a 7.5kg top loader? - Simpson Esprit 750 Top Load 7.5kg
I have a Simpson ezi Top Loader 8 Kg what does a E20 error code mean
Lift the top by unscrewing the screws in the back or remove the back panel and there you will find a code and test sheet. Very easy to follow if you follow it to a T.
Jan 20, 2016 | Simpson Washing Machines
My frigadare front loader has code E20 on it and won't drain out all water from clothes or drum
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Daniel
Nov 27, 2010 | Frigidaire ATF6000ES Front Load Washer
No spinning and no draining and i get code e20
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you!!
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Kenmore 44072 Front Load Washer
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
