Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
My auto feed trimmer/edger stopped automatically feeding the string - have to pull out the string manually, is there someway to fix this?
3 Suggested Answers
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
  • 9 Answers
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Posted on Feb 21, 2012
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Auto feed doesn't work
Take the end apart and make sure the line is not getting bound up or is not over filled to where it can not move freely
Nov 09, 2013 | Homelite 14 in. 5 Amp Electric String...
My worx trimmer line does not feed
According to the manual it only advances 1/2" so if 4" break off, you have to start/stop 8 times.
May 25, 2012 | Worx GT WG150 10 in. 18 Volt Cordless...
Lost owners manual, how do I advance the string
Hi don watts46...
Bump the rotating end of the trimmer on the ground while it is running and it will automatically feed the line out, the more you bump the more line feeds out.
Please take time to rate me
Aug 20, 2011 | Troy Garden
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
String won't advance automatically. Thank you so much for any assistance! It's a Black & Decker ST 7000 edger/trimmer.
There is a rachet mechanism at the bottom of the spool. make sure the spool is seated fully. Also make sure the string isn't wound too tight or it will stick and not advance.
Apr 06, 2010 | Black & Decker St7000 13'' Automatic Feed...
Auto feed spool doesn't work
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Automatic line feed melts together -will not feed- second trimmer to do this
The talcum powder fix that I gave for line feed problems works for this problem too. The powder lubricates the line, eliminating the friction that melts the line. They are essentially just two parts of the same problem.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
162 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
