Question about Printronix Office Equipment & Supplies
PRINTRONIX 179499-001 RIBBON - Printronix Office Equipment & Supplies
    Scholar:
  • 111 Answers
ULTRA CAPACITY RIBBON, 6-PACK which i have in stock rcardenas@themrpsolution.com
Posted on Feb 04, 2015
3 Suggested Answers
printertech1
  • 96 Answers
SOURCE: My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Posted on Mar 05, 2011
  • 826 Answers
SOURCE: crtg missing instal new ribbon printronix p7005
This error message normally happen due to following reasons..
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
4.If you inserted and removed Cartridge many times..
Try to do it: You can wipe the copper contact plate on the cartridge over with a slightly damp piece of kitchen towel using distilled water. While doing this you need to turn off your comp and printer. Let the contact plate dry for a minute or two before putting back on.
After inserting the cartridge, run the print head cleaning program 3 to 4 times for best results as this will clean the heads and push the ink through.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Nov 28, 2012
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
Dec 07, 2010 | Printronix Line Matrix P5005B Printer
I HAVE PRINTRONIX P5005B PRINTER, RIBBON IS NOT MOVING
Check to see if the plastic ribbon hub is loose on the ribbon motor shaft. The plastic hubs will crack and while the motor shaft turns, the hub will not. If so, replace plastic ribbon hub.
Nov 27, 2010 | Printronix Line Matrix P5005B Printer
Ribbon stal
34 RIBBON STALL TIMEOUT
Yes
In the CT emulation with a coax interface, the ribbon has not moved for 10 minutes after CLEAR was pressed to clear the ribbon drive fault.
Reload the ribbon.
Aug 03, 2010 | Printronix P7005 Matrix Printer
I have a problem with ribbon gear of printronix p500 line printer
in india call 09924444848 as i know he supply it otherwose printronix service center or CMS computers , or wipro help u...
Jan 08, 2009 | Printronix Line Matrix P5005B Printer
Print result p7005
You have something caught in the hammerbank cover. Sometimes a piece of lint, paper chad or some ribbon fabric will get hung in the holes and need to be cleaned out. Remove the ribbon, open the 'mask' as far as you can and look into the hammerbank area to find and remove the debris. Reload the ribbon and run a test print to see if the problem is solved. If not, the problem will usually be a hammer that is not retracting.
Oct 19, 2008 | Printronix P7005 Matrix Printer
22 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
