Question about Garden
No power/rough idle/black smoke
Have a 20 horse briggs &stratton.Was running good ,turned it off now running rough,no power,and black smoke.Replaced plug.Tractor is a craftsman.
    President:
  • 1,111 Answers
Either the choke is closed or the float is stuck open..if the float is stuck open, normally it will leak gas
Posted on Jun 23, 2009
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & stratton - after warm up engine idles rough or hunts -runs fine when cold
make sure the intake is not cracked or leaking spray carb cleaner arround gasket and carb sounds like you have a hot condition vacume leak
Jul 14, 2012 | Garden
Briggs & Stratton twin with overhead valve engine.
Hi, check the engine oil level. It will be most likely over full as it has become contaminated with fuel, if so you will be able to smell fuel on the dipstick. If thus is the
May 05, 2011 | Garden
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Sep 11, 2009 | Briggs & Stratton Garden
Briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Aug 20, 2009 | Briggs & Stratton Garden
Engine smokes and looses power
Check the air filter, replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
481 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
