Question about Swatch Watches
Cannot open battery cover - Swatch Watches
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
How do I remove the back plate to access the battery?
some watch use a back cover vacuum press to close it.
at the back metal cover, look for a small grove around the cover, using a special knife for watch, gently press upward to open.
BUT wait before you do it, note that this cover is easy to open but hard to close. you will need a special tool a press for this.
my advice better to see a rep for this.
Dec 14, 2010 | Fossil Grimm FS4154 Watch
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    How do you open the back of the Timex Ironkids wristwatch in order to replace the battery? It has four small screws and part of the plastic wristband keeps me from prying off the back to replace the...
    mcdevito75 here, Those 4 screws hold the back onto your Timex. Do not try to pry off the back cover, rather you"ll need jewlers screwdrivers to un--screw that back cover to replace the battery.
    Jul 31, 2010 | Timex IRONKIDS 70491 wristwatch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    Dead battery, how do I open?
    I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
    Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
    the details of the battery read on top the one currently inside it.
    Jan 30, 2010 | Watches
    How to change the battery
    the metal cover will be sliding and if you will slide it left or right battery should come out.
    Thanks
    Nov 25, 2009 | Kenneth Cole KC2315 watch
    My watch needs a new battery.
    There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
    Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
    How do I release the battery clip on a Timex Expedition watch to change the battery.
    I just had this problem, and my 8 year old and I had to fiddle a bit to figure it out.
    Just to confirm, you have removed the back cover and taken the watch guts out of the face and strap assembly and are looking at the battery which has a cover over it and maybe a sticker on the cover that says "unlatch to remove battery", with two >'s, one pointing to to each side?
    On each side there are two small metal tabs, which surround a small moulded-in plastic piece with an opening in the middle.
    The release is in that opening in the plastic piece. You need to fish around in that opening a little to catch the release and push it outward toward the edge of the watch (away from the battery). You need something very small to do this with, like a straight pin. If successful, the cover pops up on one side and then you do the same on the other side.
    Good luck.
    Jul 20, 2008 | Timex Watches
    Watches Logo
    Top Swatch Watches Experts
    Ansel Alberto
    Ansel Alberto
    Johannes van der Wel
    Level 1 Expert
    Are you a Swatch Watch Expert? Answer questions, earn points and help others
