Question about Apple iBook G4 Mac Notebook
How do I reconnect to the internet, I restored my iBook G4 to factory settings and although I am connected via Airport am receiving an error message that no ports are open . Everytime I try to open T
I restored my iBook G4 using Terminal with instructions I found online. My laptop was running slowly and kept freezing. Prior to restoring it I installed Onxy to try to repair it. My pointer/cursor had been jumping to different areas when I typed as well as the freezing & slow performance issue. How do I repair my iBook?
    Novelist:
  • 98 Answers
The pointer jumping on the screen sounds like you may have picked up a virus. While rare, there are mac viruses. I would try to save all my data documents and any other valuable personal files or lists, then do a clean reinstall of the operating system. Then load our documents back in.
You could try to scan for a virus with a mac virus program, but not many are available for a G4 Power PC (PPC) machine.
Posted on Aug 11, 2014
jgcalifornia
  • 160 Answers
SOURCE: ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Posted on Feb 18, 2009
actionman14
  • 32 Answers
SOURCE: Ibook G3 not conecting to internet
that just means it cant find it you need to try other setting and create a network connection,
it should see the network cable straight away try diff port on the router then dial up the ip address of the router first and change the setting . ip like 196.162.0.1
actionmab
Posted on Feb 27, 2009
  • 7 Answers
SOURCE: My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Posted on Mar 22, 2009
  • 26 Answers
SOURCE: will not connect to internet via airport
Start from scratch. Go back to your main computer and create a USB key and try that way.
Wondering, is your MAc setup for wireless?
Another thought, i had the same issue connecting my Mac to my parents wireless. I used the installation disc and that solved that.
Posted on Apr 14, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
Posted on Jun 15, 2009
My ibook won't connect to the intervet via airport or the ethernet
In your stage you can do this simple things.1. update your software call SOFTWARE UPDATEif the problem with network drivers after this step will solved it2_14_2013_7_00_24_am.jpg
2. Still the situation same... Reinstall with Install and Restore disk which came with the iBook (OS X 10.3 or 10.4).
Feb 13, 2013 | Apple iBook G3 Mac Notebook
Can my apple ibook g4 work without an airport extreme card
If you mean 'work as a computer' then the answer is yes.If you mean 'work on the internet' the answer is yesIf you mean 'work wirelessly on the internet' then the answer is no.
You can use an ethernet cable to connect to your Router and that will give you the internet.
Feb 18, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Reset_To_Factory_Setting on mac ibook g4
Justin I suppose the easiest way to do this would be to insert your system disk into your ibook boot it up holding down the c key on your keyboard and then instal a fresh system. Use the erase and instal option as this will erase your hard drive. Any other queries get back to me, hope this helps. By the way a step by step way of doing this can be found at http://macs.about.com/od/leopard105/ss/installleopard.htm although it's leopard it should be similar across system.
Oct 31, 2011 | Apple iBook G4 Mac Notebook
Won't connect to internet via wifi anymore
When the power gets low, it will do silly things like turn off wireless to save battery. Prolly you just have to turn it back on. Click the airport symbol in the upper right hand area of your screen. Looks like a triangle made out of curved lines. A menu will drop down and one of the options will be "Turn Airport on". Click that.
Nov 07, 2009 | Apple iBook G4 Mac Notebook
Problem with wireless connection. Our router is hooked up to the pc in the living room but having trouble connecting my iBook G4 to the router using the wireless Airport in my Mac.It always connects to...
Sounds like you need to enter the ISP's DNS server number into the airport settings.
Maybe you do not have it set to acquire addresses automatically? Auto is usually painless.
You should be able to find it in the router settings.
Just write down the DNS number and put it into Airport.
Also check that you have the Gateway set correctly, it could be the IP address of the router or the modem, depends on your configuration.
Oct 15, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Ibook g3
First of all, you need an Airport card for the iBook G3, chech for example this link; http://popular.ebay.com/ns/Computers-Networking/Original-Airport-Card.html (you should buy one like this: 9deeeda.jpg
, there is a G4 card too, but your iBook doesn't support this one).
Next, install it;
Then, buy a wireless router that uses 802.11b/g or 802.11b. This is very important because your airport card doesn't support 802.11g, and install it, but don't protect your network with a WAP password, your iBook doesn't support this, but use WEP.
Then start your iBook, and click on the Airport icon in the right corner, select your network, type in the password and it will work!
Jul 01, 2009 | Apple iBook G3 Mac Notebook
USB reads wireless modem, software doesn't!
mac doesn't support any data card till date so this is not working . if you want to connect it install windows using bootcamp then your problem will be solved. if something importent rate this article
May 09, 2009 | Apple iBook G4 Mac Notebook
Will not connect to internet via airport
Mar 26, 2009 | Apple iBook G4 Mac Notebook
Ibook g4 freezes and airport problem
Feb 16, 2009 | Apple iBook G4 Mac Notebook
SMC 11n Router: wireless set-up
Hi there!
Do you know how to check the wireless IP address at your iBook?
May 04, 2008 | Computers & Internet
Apple iBook G4 Mac Notebook Logo
93 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
