Question about HP DeskJet 845c Printer
It was suggested that I buy a new printer cartridge for my HP Deskjet 845c rather than use a refill, which causes the cartridge light to blink. I did go out and buy new cartridges for both color and black but before I open the packages, I want to know if it's normal for the light to continue blinking even if there are no cartridges in the printer. In case it's something else, I don't wanna eat the price of the cartridges.
  • 1 more comment
  • krk2 Jun 23, 2009
    There's only a 2 dollar difference between them. I've never installed only one cartridge. There is nowhere in the instructions where it says you have an option to install only 1 cartridge or 2. Will the printer accept 1 cartridge as a valid installation?
  • krk2 Jun 23, 2009
    O.k. Here she goes. I installed the black cartridge alone and THE BLINKING STOPPED. Then I went ahead and put the color one in. The green light is steady. I can drive now! Thanks guys! You rock the Western hemisphere.
  • krk2 Jun 23, 2009
    Yes. I did remember to do a rating. All thumbs up!
    Brigadier General:
  • 4,090 Answers
I dont know if anyone has logged this, but i would think that logically the lights would continue to blink until it detects the right amount of ink density and If they are chipped that the chip registers correctly. Ttry installing just one of the cartridges ( the cheaper one)
Posted on Jun 23, 2009
  • dennis bullard Jun 23, 2009
    i suggested this to determine if the flaqshing light under that particular cartridge ceased to blink. i cannot find any reference to blinking between one type of cartridge or the other as no company wants to supply info about dodgy refills and their own overpriced products. in this situation it is unfortunately a **** it and see situation. I would expect that if you now have genuine cartridgs it will work but it is a guess as i said at first
    OK thanks for the feedback love it when i get it sorted for another user dont forget to do a rating it helps the cause
HP DeskJet 845c Printer - "My deskjet 845c printer not printing after formatting"
You need to install the printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Feb 02, 2013 | HP DeskJet 845c Printer
Hi Bought a new notebook with preloaded Vista trial OS.Hoping to buy Win 7 soon.I am not able to print to my HP deskjet 845c printer and error printing appears in status window.Prints fine from another...
Hi welcome to Fixyah,
Disconnect your HP printere from your usb port and then reconnect it back and use another USB port. Make sure that you install the driver for your printer and then try it again.
Aug 10, 2010 | HP DeskJet 845c Printer
My hp deskjet 845c won't print pink. I've tried two different ink cartridges and no pink ink. Is my printer probably on it's last leg? I have also tried cleaning the print heads...didn't help.
Are you using HP factory new cartridges?
If you are using third party or worse, refilled cartridges, that may well be the cause of your proiblems.
Don
Feb 24, 2010 | HP DeskJet 845c Printer
Hi i have a deskjet hp 845c printer.The problem i have is that the 3 lights keep flashing then the power turns itself off.Ive tried upluging it and changed the ink cartridge.Please can you help?
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Nov 10, 2009 | HP DeskJet 845c Printer
Printer
hello ! please check if the catridges is seated well .may be the sensor have not detected the catridges ., so as to reset the printers memory .
good luck
Jul 08, 2009 | HP DeskJet 845c Printer
Hp Deskjet 845c printer's cartridge light blinks constantly.
It probably has, the printer might not detect your cartridges properly, try using new ones
Jun 22, 2009 | HP DeskJet 845c Printer
Where can I Buy HP Deskjet Color 845C Printer - model #C8934A?
hi,
this model is obsolete in the market rigth but you can buy it on a computer shop that sell a surplus item..
rey
Nov 03, 2008 | Office Equipment & Supplies
HP Deskjet Color 845C Printer - Black Cartridge Problem
hi,
try to clean the nozzle with clean cotton w/ alcohol i think your cartridge has getting clog..or maybe it's getting empty!
rey
Nov 02, 2008 | HP DeskJet 845c Printer
Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Jan 31, 2008 | HP DeskJet 845c Printer
Hepl me find and download a driver
Firstly make sure that they are original cartridges as most problems are caused by faulty cartridges. Then clean the gold contacts with a soft cloth. install cartridges and turn machine on hopefully this will work if not then the machine has a carriage fault.
Hope this helps you
Thanks J
Dec 10, 2007 | HP DeskJet 845c Printer
HP DeskJet 845c Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
