Question about Nokia 1600 Cellular Phone
Nokia 1609 is asking security key - Nokia 1600 Cellular Phone
Formate nokia310
Please always Remember, while doing Master Reset Nokia Asha 311 to factory default, the data will be loose, that's why we can do backup all data or important stuff at Nokia Asha 311.
#Option 1, Hard Reset Nokia Asha 310 & 311 with menu setting:
  1. Make sure the Nokia Asha 311 on and standby
  2. Go to menu Setting, then choose restore factory setting > settings only
  3. It will ask security code, input default security code of Nokia Asha 311 : 12345
#Option 2, Hard Reset Nokia Asha 310 & 311 with special code / master key / shortcut / secret key :
  1. Try to type: *#7370# and it will ask the security code of Nokia Asha 311, press 12345
  2. You also can try type: *#7380#
#Option 3, Soft Reset Nokia Asha 310 & 311 with special key code :
Please take attention, this option is for soft reset, so Nokia Asha 311 will not removing any important data and installed applications. How soft reset Nokia Asha 311 work: It will recopy or restore the default copy of .ini to Nokia Asha 311.
  1. Type in the phone : *#7780#
Jul 31, 2013 | Electronics - Others
Tip
How to format Nokia N- Series mobile
This is common problem that how to format Nokia N- Series mobile
Three methods are given below by which you can format your Nokia N- Series mobile
Method 1:
First of all Switch off your mobile then press and hold 3 keys combined
  • Green dial key (Call answer button)
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the mobile.
  • In the process don't leave the 3 press and hold keys
Now
wait for message "Formatting" to appear on the screen and release all keys once you see that message.
If it as security code then default security code for Nokia is 12345
Method 2: Hard Format
  • Type *#7370# from your dial keys
  • It will ask you to confirm that press OK
  • It will take some time and your mobile will be formatted & restore settings to default factory settings
  • If it as security code then default security code for Nokia is 12345
Method 3: Soft Format
  • Type *#7780# from your dial keys
Note: Remember one things by Method 1 & Method 2 this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your mobile is like a new mobile. So better is first save all your data and then format it. By Method 3 (Soft Format) it only restores your mobile & do not delete your data.
If it helps you Please Click on "Yes" that it helped you
on Jan 17, 2011 | Cell Phones
My nokia 2690 is key pad lock when i unlock my keypad,my phone is asking security code. what i have to do?
The Nokia default security code is 12345, this may work if the security code has not been changed.
Jul 16, 2011 | Nokia 2690 Cell Phone
I have a nokia 6275 CDMA mobile but i dont kown the security code of this mobile my phone's code is 0546114D00651........Plz help me
hi:) u need go in phone setting,sellect SECURITY,ACCESS CODES,CHANGE SECURITY CODE. key in your own code,they will ask u enter new security code. u juz key in 12345. then go select SECURITY LEVEL,key in 12345,select NONE. that all. Good luck :)
Jul 06, 2010 | Nokia 6270 Cellular Phone
My nokia 1108 is locked and askin for a security code
my phone is locked nokia 1108 asking for a security code which was reset by someone now i could not open my phone please help me?
Jun 19, 2009 | Nokia 1100
How to reset security code for nokia 3120 classic, i cant use my phone...
I put a security code to my Nokia 3120 classic mobile. But suddenly it asking me the security code n when i provide the correct one it says code error. www.UnlockMe.co.uk doesn't work. They mentioned there that 3120 classic phone is incompatible for this master code method. pls give me a solution......
Jun 07, 2009 | Nokia N72 Cellular Phone
Problem of Umax 610P installation in xp
ىةىىىىررررررررررراىىىىىىىى
Feb 20, 2009 | Umax Astra 610P Flatbed Scanner
Phone restricted
الموبايل يطفىء عندما اضعة فى جيبى
Mar 26, 2008 | Nokia 6610i Cellular Phone
Nokia 1600 security code
If your phone is prompting you for a security code and you have not activated one, please try the following:
  • Enter the default security code: 12345. Only try this once.
Please see this link for more information:
http://www.nokia.com.hk/nokia/0,,78536,00.html#2
Oct 29, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
21 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
