Question about Boating
Do I have to cover my trailer boat when towing?
I have a 4.4M tinny on a small boat trailer. Am I required to put a net/cover on it when towing
    Problem Solver:
  • 10 Answers
Agree with first answer that a cover is not required. One consideration is drag- an uncovered boat has significantly more aerodynamic drag than a boat with a well-fitted cover- maybe equivalent to pulling an extra 1000 lb for a 3000 ski boat. This may not be a big deal on a small boat like 4.4meter.
Posted on Dec 02, 2014
  • phillipelecu
    phillipelecu Dec 02, 2014
    Agreed, Especially if there is equipment up in the airflow (console, ski/tow rack, etc). One major problem is to acquire a "well-fitted" cover. Factory produced(boat manufacturer) usually fit the best. After market are notoriously ill-fitting. A loose cover that flaps in the airflow can be worse than no cover and may self destruct on the first trip.
  • jgcfamily Dec 02, 2014
    True that. BTW - I had a cover made that comes down over the sides and secures with a drawstring, frons and rear straps- I can leave the side straps off while trailering - man is it easier to put on and off than my original snap-on cover.
    Champion:
  • 254 Answers
I do not know the rules of your state but I do not know any that require a cover. The bout should be strapped down to the trailer and anything that can blow out should be removed. I followed a boat the other day that had a hatch unfastened. Round things were blowing out as the lid flopped in the wind. I stopped him, then went back to see what came out. He will be unhappy when he gets on the water and finds he does not have any leader line left.
Posted on Nov 26, 2014
2 Suggested Answers
  • 124 Answers
SOURCE: I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
Posted on Oct 16, 2013
Can you drive a SUV towing a boat with 2 passengers ?
if the passengers are using the seat belts and are inside the car-- yes
there can be no one in the boat being towed and all items ( cooler , rods , seats etc) have to be restrained with a device like a cargo net
remember that there may also be speed restraints on towed vehicles
Mar 04, 2017 | Cars & Trucks
Can we safely tow a 206tonne boat. The ute is a diesel
not enough information
to tow anything , there are regulated engine power requirements , braking capacity, electric break away brakes on the trailer, weight on the tow bar, boat width, boat length
All the requirement can be found at the vehicle registry office or main roads department
Jan 06, 2017 | Cars & Trucks
What's the towing capacity for dodge caravan 2000? can't seem to find it on the net...
I've got an 05 model with the 3.3 and given what I know I wouldn't pull anything over 2k lbs a small utility trailer with a riding mower or a small 14-16 ft boat or wave runner would be the extent of it without having a heavy duty transmission, a seperate trans fluid cooler, and an elec braking device
Apr 28, 2011 | 2000 Dodge Caravan
What is the towing ability of a 1999 jeep cherokee
provided its just a base model (not 4wd) you could tow a load up to 3000 pounds (small boats, utility trailer with riding mower etc.) without adding excessive strain on motor/transmission easily enough. Just make sure your hitch is rated for whatever you intend to tow class1-3
Jan 07, 2011 | 1999 Jeep Cherokee
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
Replace an actuator on my boat trailer.
You may be able to tow without the surge brakes. A lot depends on the weight of the tow vehicle and its stopping ability. The trailer brakes may be leaking on the trailer brake shoes. This may cause the linings to swell and lock up.
You can make the brakes inoperative by putting a bolt through the moving parts and converting it to a solid tonque. There may be legal regulations about operating it on a highway without the safety device.
Not much is inspected in my area, but your insurance may be void if you have an accident.
Jul 24, 2010 | Boating
What is the towing capacity of a 2004 Solara?
Not trying to sound like dodging the question but, If it's not written in your owners manual, your best bet is to call local toyota dealer & ask to be sure. Wouldn't want to guess on that & end up blowing your transmission or engine.
Feb 28, 2009 | 2004 Toyota Solara
Loading back on traiker
Float on style trailers are designed with immersions depths and vertical guides to allow the boat to be driven onto the trailer. But not at full throttle, only enough power to move the boat over the bottom rollers/guides. Some trailers are designed to have the boat winched onto the trailer. For this style, you drive to boat to a starting point and then use the winch to pull the boat the remaining distance. These sometimes have a release mechanism and hinge/pivot point to allow the back of the trailer to drop below the normal towing position to make recovery easier. As the boat is winched into position, the weight of the boat will cause the trailor to pivot and return to the towing position.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Boating Logo
552 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
