Question about Little Giant Submersible Fountain Pump
My pump is running but not sucking up water
My pump stopped pumpping water and ther is nothing blocking the entry
  • 2,760 Answers
Well if possible look into suction screen and see if Impeler is turning , I'll bet not , most of the lil giants come with a easy to remove pump cover (screw) so one can access the pump cavity to remove forign debris , also one can manually rotate impeller with finger (unplugged) to ck for free movement , if its hard to move your pump needs replacement
Posted on Jan 31, 2015
My pool pump is not sucking enough water threw it and releasing it very slowly what do I do.
check for blocked inlets and filters check that the control tap is position properly as it may be recycling water and not direction the flow properly
check if the pump is running at full speed ( bearing problem)
failing that have a pump specialist check it out
Aug 03, 2015 | Pool & Spa
My Neff dish washer runs for about 30 sec to a 1 min then just turns it self off the water pump sucks water in ok and the pump takes the water out ok ? help
that sounds like normal operation......the pump takes out remaining water then stops and lets in new hot water.
Oct 26, 2014 | Neff Dishwashers
Grundfos pump problems
There are several possibilities here. All involve water pressure. The first is that you have a water leak between the pump and where the water is going to.
The second is that the pump is not getting enough water to it so it is sucking air well as water in an attempt to give you water perssure. This could be caused by not having an inline "one way" valve on your supply line just before the pump ($30.00).
The third involves two little screws on the control where your electical connection is. These two screws control the high and low pressure settings of your pump. If your high setting is too high the pump will simply keep running trying to do the impossible, If there is not enough difference between the high and low setting the pump will also keep on. running.
Another possibility is that the pump has had debris (sand, dirt, mud, etc) sucked through it and has damaged either the housing or more likely the impeller that spins the water creating the pressure.Ther is also an internal seal that can be damaged by debris.
The final possibility is that the pressure control unit with the two little screws I mentioned earlier has failed and is deffective.
Most importantly if the pump is running hot please stop using it! You are at risk of fire and possibly the loss of your home and loved ones. Grundfos pumps can be serviced by a professional technician, Parts are readily available and not extremely expensive. I would not recommend doing it youself if it is the pump.as some specialty tools may be involved depending on the problem. You will become frustrated very quickly.
A fast solution is to buy one of the cheap plastic pumps ($169.00) made in China. They are amazing for the price and will run with no problems for years if your water is free of debris. Fixing your Grundfos may run you the same amount and you maybe without a pump for a week or more depending on the technicians work load.
I am not saying "Don't fix your Grundfos" but you don't need to be in a panic about it either.
Sep 06, 2014 | Grundfos JPS4 1 HP Pressure Booster Pump
GroundFOS water pump won't stop running after replacing PVC pipes
you may have to blead air from the water lines. air pokets will not let your pump regulaet. as your pump feeds water into the filter and all your house hold pluming it must reach a set presher. if ther is air trapt in the sistem it can not build enouph back presher to force the pumps PSI regulaeter switch to ingaidge. air is lighter then water ther for thes to difrent forces pushing against one another couses a flucksuaition and can not regulaet. blead all lines from the pump to all outlets"fosets,spikets and filltering sistem. let pump run while going to all outlets one at a time opening and closeing "cold side first" them to releave the air from the lines. donot forget eny outside fosets this should solve the problem. thank you for leting me help you today .
Feb 17, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
I have a submersible water pump It seems to suck ...
That is pretty much par for the course with a submersible pump. Eventually the pump will be damaged by running dry as it depends on the water to keep it cool. Can't you set it up a little on something so it won't **** dirt?
May 20, 2010 | Garden
For pressure washer Model WP-2402-SWHB, SN 10132043: With Honda engine running, or no engine running, no water will pass through the pump.
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Dec 11, 2009 | Garden
Won't spin or drain
most of the time wen this happens ther is a foreign object stopping the drain pump from working.if you still have water in the tub use a shop vac attach it to the drain hose to **** out all the water then pull the hoses of the drain pump and look inside for something stopping the pump if there is nothing found replace the drain pump
Sep 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Duet
yes it should run continuosly,(at least untill the water level drops.) a more common instance withthis machine is that the drain line is blocked/restricted, or somethingis ninthe pump housing. it is even possible hat the pump impeller has dislodged from the housing and although it sounds as if its "pumping" its moving no water..usually in htis case your able to open the filter assembly and "pushback on hte impeller(normal impeller will not ,ove back" however if it was dislodged it will have foward play.i would even blow out the drain hose form the pump to the drain standpipe, just in case.
F02 is def a long pump out time and no ther ewill be no high speed spin with water in unit(or if it thinks thers water in unit)
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Little Giant Submersible Fountain Pump Logo
147 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
