Question about Garden
2012 kubota 326 diesel zero turn mower, starts but will not move.
2 Suggested Answers
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
#1 my kubota gr 2120 diesel lawn tractor wont start in todays minus six degrees even I used the glowplugs. #2 i wanted to push the tractor out of the barn wont budge?
Throw a tarp over the tractor. put electric heater under tarp and warm the tractor up. #2 Most hydrostatics have a release lever that allows them to be moved.
Nov 20, 2014 | Diesel Garden
Kubota zero turn mower
You probably picked up some contaminate from the bottom of your tank... Try some carb spray but it will probably require a good carb cleaning...
Aug 02, 2014 | Kubota Garden
Kubota diesel sit on lawn mower HST G1700 starting problems
I turn the key on my kubota hst g 1700 and I hear it clicking but doesn't turn over. Someone told me there is a common wire fault somewhere. Can anyone help. Thank you
Mar 30, 2013 | Garden
Can I adjust or take out thermostat in my Kubota D902-E diesel motor it overheats
u need to find the cause, here is a easy rundown. 1/ make sure water levels are full,remove radiator cap start up and let run about 1/2 throttle if starting to get hot and no water shouting out of rad. its not a head gasket2/whiledoing step 1 can you see thr water moving thru the system . if so.not water pump.3/ replace thermostat make sure fans come on good luck
Oct 22, 2012 | Kubota Garden
My 21 HP diesel zero turn mower starts blowing black smoke after running at higher throttle settings and temp gauge shows engine is warm. No air restrictions. New fuel filters. smooth running when cool or...
Looks like you've got a good idea on what makes diesels smoke, so I'm sure you know that black smoke is almost always from too much fuel for the air that's going in. So it can be too much fuel or too little air. If your filters are good, the next things to check are the fuel pressure and the injectors.
I know diesels, but I don't have any specific experience with lawn mowers (kubota?). Since it stalls eventually, it sounds like it's not a single cylinder (although not for sure) so I'd check injector pump first.
Sep 28, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
