Question about Lifespan Exercise & Fitness
Lifespan traction II error code E6 Mat is not running
Mat is not running.i cannot hear the motor running.Error code is E6
5 Suggested Answers
SOURCE: my Lifespan treadmill is showing an E1 error code.
my lifespan treadmill has an error code e1
Posted on Mar 21, 2010
  • 39 Answers
SOURCE: my lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
Posted on Oct 19, 2011
ercupa190
  • 12223 Answers
SOURCE: lifespan tr1000 sl, runs for
abrupt shutdown of the belt as the motor control detect a sharp increase in drive
current and inmediately stop driving belt.Some situation as jamming the belt may cause this error.Without such abuse should be a cause for extreme care and analysis for some Tech.
2 reason:
1) Motor drive; possible faulty(Test)
2) motor control board : possible faulty(Test)
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Posted on Nov 12, 2011
ercupa190
  • 12223 Answers
SOURCE: Problem with the lifespan 1200i
1( adjust the speed sensor, clean, and tight the wires connector.
see the diagram attached.
2) Test the input voltage motor, if there are voltages, the motor need repair.
3) Test the output voltage board, for input voltage motor,if there ARE NOT voltage the boar is faulty.
God bless you
Posted on May 16, 2012
What is error e6
e6 error air conditioner Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your e6 error air conditioner question. Get free help, tips & support from top experts on e6 error air conditioner related issues.
air conditioner e6 code Questions & Answers - Fixya
...one inverter 12k I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication ...
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 1 of 3 for Mitsubishi Electric .... Ductless Air Conditioner ...
Jan 23, 2016 | Heating & Cooling
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Error code E 7
proceed according you have two alternative: see the diagrams . God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 22, 2013 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
Jan 20, 2013 | LifeSpan Fitness TR200 FoldNStor Compact...
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
My lifespan treadmill has error code e6, what does this mean?
Oct 19, 2011 | Exercise & Fitness
I have a LifeSpan TR1000-SL that stopped running. We are getting an E1 error code and do not know what this means or how to fix it. Ayy help you could provide would be much appreciated. Thanks in...
2 reason:
Aug 09, 2011 | RTO Lifespan Fitness TR1000 Sl Treadmill
My sportsart 6150 treadmill gives an error code 1 when the speed button is pushed. motor moves slightly but then gives error code 1. thanks.
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Jan 23, 2010 | Exercise & Fitness
Exercise & Fitness Logo
Top Lifespan Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Mike
Mike
Electro Med Services...
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
